Items with no label
3340 Discussions
Bad frame rate in Linux for D435
VK_R
I wanted to try the performance in Linux. But fiddling with some example code, I am not able to achieve the set frame rate among the res and fps combinations available. Setting it to VGA @ 30 fps, I'm hitting around 17 fps. I built the sdk using default settings on cmake. Any suggestions would be appreciated.
Parameter Value Camera Model D435Firmware Version 5.8.15.0Operating System & VersionUbuntu 16.04Kernel Version (Linux Only)4.13.0-32Platform PCSDK Version 2.9.2
MartyG
There were a couple of cases in early 2017 where users were finding with the old Windows SDKs and the older SR300 camera model that their camera speed was capped at 17 FPS no matter what resolution they tried or ample program they ran. A definitive cause was not identified though, and in one of those cases the problem fixed itself on its own.
There was a bug in early versions of SDK 2.0 that caused FPS to drop by 50%. The bug's reference name was DSO-7183. It was marked as fixed though in a subsequent version.
There were also a couple of rare cases where the FPS was being dragged down because the lighting in the room that the camera was being used was too dim. Is the lighting in the location where your camera is being used at a relatively normal level?
