Items with no label
3341 Discussions
BadImageFormatException, when trying to run C# project - Intel realsense SDK
JOzol
Every time i try to compile i'm getting this error:
  1. System.BadImageFormatException: 'An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)'
when i try to run session = PXCMSession.CreateInstance();
I'm running Windows 10 pro, 32 bit operating system.
Added reference to file:
c:\Program Files\Intel\RSSDK\bin\win32\libpxcclr.cs.dll
added to post build evenent:
if "$(Platform)" == "x86" ( copy /y "$(RSSDK_DIR)\bin\win32\libpxccpp2c.dll" "$(TargetDir)" ) else ( copy /y "$(RSSDK_DIR)\bin\x64\libpxccpp2c.dll" "$(TargetDir)" )
And in build tab changed platform target from Any CPU to X86
MartyG
Edit: originally this was a post titled 'BadImageFormatException, when trying to run C# project' but later got mysteriously replaced with the title 'Bn' and only containing the message 'n'
Are you using the '2016 R3' SDK? R3 has a very different structure to the previous SDKs and uses a library file with a different name - libpxccore_c.dll - and totally different folder location. So if you are using R3, your program may be looking for a library file reference that no longer exists in that SDK.
Hi zaholk,
I've fixed the title and the content of the tread so that the original message is displayed. Go ahead and try the suggestion posted by @MartyG and let us know your results. We'll be waiting for your response.
@MartyG-Thank for helping out!
-Sergio A
Hi zaholk,
Do you still need assistance with this thread? Let us know your results of trying @MartyG's suggestion.
-Sergio A
