Items with no label
3341 Discussions
Bug - file .sof that is loaded in board apparently stop been update when I compile
NAGUALL
Bug - file .sof that is loaded in board apparently stop been update when I compile.
I found out that problem when I turn my board off and on...then change my project drastically, compile, load it into the board and it still behave like my last project...
So I copy all my .vhd files, create a new project and just then the correct code was loaded into my board.
Anyone else experience that problem? Is there a solution for not experience it again? That kind of problem really mess with the troubleshoot and tests...
Or there is a well-kwnown cause for it to ocorrs? (I mean, maybe something I doing wrong that can cause it?)
