Items with no label
3341 Discussions
Build exe with fail ,but work well in unity editor
FAssi1
however ,thank u all did before ,I have already modify the value of system enviroment ,and works well in untiy editor mode ,but ,whenever i want to build a exe with unity ,it seems not work .even the red light is off ,and i try to log the error ,It seems connected fail,I want some help from u ,it is no more time for me ..thanks a lot
MartyG
When building a standalone exe in Unity, the scene in the editor that you want to build should be configured in the Build Settings window, accessed in the 'File > Build Settings menu option.
Once you are on the Build Settings window, do the following steps:
  • Click on the 'Add Open Scenes' button to add your currently open scene in the editor to the list of scenes for Unity to build into an executable.
  • Make sure that the 'Architecture' drop-down menu is set to the 'x86_64' option to tell Unity that you are building a 64-bit application.
  • Finally, click the 'Build And Run' button to build the executable.
If you are using a D415, the Unity wrapper of RealSense SDK 2.0 (or a wrapper compatible with the 400 Series cameras) is your only option to build a Unity RealSense application.
MartyG
Which RealSense SDK are you using please? Are you using the current one (RealSense SDK 2.0) or one of the older SDKs ('2016 R2' or '2016 R3'). Thanks!
FAssi1
Realsense SDK2.0 is used , otherwise I think it won't work well in unity editor .is there any other setting to build a exe to do ?​
FAssi1
D415 is the hardware ​
MartyG
FAssi1
Wow....thank u very much,the problem is solved.
MartyG
Awesome news! I'm very glad I could help. Have a great day!
