Items with no label
3341 Discussions
Building RealSense SDK 2.0 on rooted Android devices
MartyG
Hi everyone,
I thought I would highlight an interesting documentation page about building RealSense SDK 2.0 on rooted Android devices.
https://github.com/IntelRealSense/librealsense/blob/development/doc/android/Android.md librealsense/Android.md at development · IntelRealSense/librealsense · GitHub
bwang44
Dear MartyG,
I can successfully start streaming depth data from D415 to a rooted Android device with:
1) RS2_STREAM_DEPTH, RS2_FORMAT_Z16, 480x270, 30 FPS.
or
2) RS2_STREAM_DEPTH, RS2_FORMAT_Z16, 424x240, 30 FPS.
However, the following configurations are not working:
1) RS2_STREAM_DEPTH, RS2_FORMAT_Z16, 640x360, 30 FPS.
2) RS2_STREAM_DEPTH, RS2_FORMAT_Z16, 640x480, 30 FPS.
3) RS2_STREAM_DEPTH, RS2_FORMAT_Z16, 848x480, 30 FPS.
4) RS2_STREAM_DEPTH, RS2_FORMAT_Z16, 1280x720, 30 FPS.
Could you please help me to check what seems to be the problem?
Thanks a lot!
Bryant.
bwang44
Dear MartyG,
I've also tried to start streaming color data from D415 to a rooted Android device,
however, all the following configurations are not working:
1) RS2_STREAM_COLOR, RS2_FORMAT_RGB8, 480x270, 30 FPS.
2) RS2_STREAM_COLOR, RS2_FORMAT_RGB8, 424x240, 30 FPS.
3) RS2_STREAM_COLOR, RS2_FORMAT_RGB8, 640x360, 30 FPS.
4) RS2_STREAM_COLOR, RS2_FORMAT_RGB8, 640x480, 30 FPS.
5) RS2_STREAM_COLOR, RS2_FORMAT_RGB8, 848x480, 30 FPS.
6) RS2_STREAM_COLOR, RS2_FORMAT_RGB8, 1280x720, 30 FPS.
Could you please also help me to check what seems to be the problem?
Thanks a lot!
Bryant.
MartyG
I believe that the camera is being treated as though it is plugged into a USB 2.0 port instead of a USB 3.0 one. In USB2 mode, the camera is limited to the depth resolution that you listed.
