Hi, I am looking at the sample here:
This sample shows the RGB and depth stream on "Image" in WPF. But my application is using windows forms. How can I show this same thing on 2 "PictureBox"?
I think I need to update this part of code. I am also kind of new to C# and just learning it. thanks
private void SetupWindow(PipelineProfile pipelineProfile, out Action<VideoFrame> depth, out Action<VideoFrame> color)
using (var p = pipelineProfile.GetStream(Stream.Depth) as VideoStreamProfile)
imgDepth.Source = new WriteableBitmap(p.Width, p.Height, 96d, 96d, PixelFormats.Rgb24, null);
depth = UpdateImage(imgDepth);
using (var p = pipelineProfile.GetStream(Stream.Color) as VideoStreamProfile)
imgColor.Source = new WriteableBitmap(p.Width, p.Height, 96d, 96d, PixelFormats.Rgb24, null);
color = UpdateImage(imgColor);
There was a very similar case to yours during the past week on the RealSense GitHub site by a user called 'jinxzzz'.
https://github.com/IntelRealSense/librealsense/issues/3413
That case is still open and the Intel staff there will be aware of it, so if you require further help if the information posted there already does not solve your problem, I recommend adding a further comment to that GitHub discussion.
