Items with no label
3341 Discussions
Camera SR300 Virtual Driver vs Camera SR300 RGB
HOlse
Now that I have the SR300 Installed, I get 2 (3 actually) new camera choices. I'm not sure which is correct to select; virtual or RGB? I cant find any documentation on this. Any suggestions or insights as to the differences and which to use, when?
Hi HowardOlsen,
I would love to help you with this, but can you explain me a little more about your issue?
I'm a little confused, what you mean with "which is correct to select"?
I will be waiting your explanation to help you more.
-Leonardo
HOlse
These two screenshots should tell the story When I installed the DCM xxx-xxx and the camera I now have 3 new camera choices in both device manager and in in the camera selection pull down menu in all of my video apps ....
Hi HowardOlsen,
You should use the RGB driver to use the camera, the Depth driver it for the laser that the camera uses to measure distances, and the virtual driver is an AVStream driver running on the client Windows system.
I hope you find this helpful.
Have a nice day.
-Leonardo
Hi HowardOlsen,
Do you have any updates about this?
-Leonardo
