Items with no label
3340 Discussions
Can I connect realsense camera module with Pixhawk??
I'm just learning a little bit with C++ and Arduino Nowadays
I have big interest with programming and drone So I'm planned to make autonomous obstacle evading drones.
So I'll buy pixhawk 2
Pixhawk 2 has Edison carrier board inside.
can it be connected with Realsense camera without mini PC or Raspberry Pi or Aeroboard?
I want to make my own code and obstacle evading Algorithms... can it be possible??
JDill1
The answer is "no". The RealSense cameras need USB 3.0. I am using the Intel Joule and also the NVidia Jetson TX1 with my RealSense cameras. You can't connect a RealSense camera to an Edison either as it does not have USB 3.0. I have 4 Edison boards in the project I'm working on, but they are positional sensors only. Use either the boards I suggested, or the Intel Aero board. I am using one also.
MartyG
Intel already has a ready-made RealSense drone kit that is due for release any time now (store listing says mid January 2017). It costs $1100.
http://click.intel.com/intel-aero-ready-to-fly-drone.html Intel® Aero Ready to Fly Drone - Intel® Aero Platform Developer Kits
Intel also demonstrated a RealSense drone with evading capabilities in January 2015, demonstrating that it is indeed possible if you want to build your own RealSense drone system instead of using their Aero kit.
https://www.youtube.com/watch?v=f0HoyJbYCPQ Intel® RealSense™ 3D Camera Drone | Intel - YouTube
I believe that early model used in that 2015 video was based on a board with six R200 cameras arranged in a 360 degree circle.
http://bit.ly/2jVQjVG
The new Aero drone kit seems to use a single R200.
Thank you for your reply
but I dont want to make it with Intel Aero kit.
I have many drone controller system so I want to connect it with real sense, not with Intel Aero kit
First of all, the kit has too high price.
I just need intel realsense module.
If it has no compatibility, I'll may use Microsoft kinect
there was no try for connecting realsense with Existing Flight Controller so I want to try it... and I want to hear your opinion
and, pixhawk(drone flight controller system) has Edison Chip inside. can it be compatible with realsense?? they have Edison chip but cant it be compatible with realsense?? I want technical support team's opinion
MartyG
RealSense has been successfully connected to Edison. I can confirm that much.
https://software.intel.com/en-us/articles/using-intel-realsense-technology-in-combination-with-the-intel-edison-development-platform Using an Intel® RealSense™ 3D Camera with the Intel® Edison Development Platform | Intel® Software
Regarding whether RealSense will work with the Pixhawk's Edison chip specifically, this is likely to be a question that is best asked on the Pixhawk support forum. An extensive search found no exact examples of Realsense being used with a Pixhawk via Edison, unfortunately.
I want to use it for evading obstalcles autonomously...
JDill1
QLi15
Hi PR,
It's good to find someone with experiences on Joule, TX1 and Aero. Which linux systems are you using on these boards? I'm thinking of using one of these three with openpilot or cleanflight (because they are cheap and can output to ESCs), and do light image processing and sensor fusion. Which one do you recommend?
Qiang
Unvisiable
Yes, the camera requires USB 3.0. Maybe you can try to use https://www.sinoseen.com, I have used their usb3.0 camera module, it is quite good, I don't know whether it meets your requirements.
