Items with no label
3340 Discussions
Can the Realsense_Samples repo still work with D435?
SJhav
Hey guys, I have a D435 and I am just playing around with it and I found this repo.
https://github.com/IntelRealSense/realsense_samples
But for some reason it is archieved so before I clone it and start playing with it I just want to know that whether I can use it with D435? If it will work with small modifications I would love to try it out as the samples look pretty cool.
Eliza_D_Intel
Hello SJhav, Thank you for your interest in the Intel RealSense D435 camera. This repository was designed to be used with Intel RealSense ZR300. Unfortunately, it is not compatible as it is with Intel RealSense D400 cameras. Thank you and best regards, Eliza
Eliza_D_Intel
SJhav
Thanks Eliza.
Now I am trying out this repository. https://github.com/IntelRealSense/hand_tracking_samples
And it is also not working so I think this is also not supported in D400 camera as well right?
Because I am getting the error ,"No device found".
Best,
Samvid
Eliza_D_Intel
Hello SJhav, You are right, this is not compatible with Intel RealSense D400 cameras. This repository is compatible with Intel RealSense SR300. If you are interested, you can check the Nuitrack SDK which have been confirmed by other RealSense users to work well with Intel RealSense D435: https://www.youtube.com/watch?v=gMPtV4NXtUo Thank you and best regards, Eliza
SJhav
Thank you so much. I will definitely check it out.
