Items with no label
3341 Discussions
Converting RealSense Pointcloud to PCL Pointcloud
EMráz
Hello everyone,
I know this has been questioned few times, but I would like to make this clear - not only for me, but for everyone trying to implement this.
What I am trying to do is basically to convert the pointcloud data from RealSense camera (D415) to PCD format, which is conventional in PCL (pointcloud library). By saying pointcloud data, I mean depth data + RGB data - if you combine these two you get exactly the same as in realsense viewer, when you hit the 3D button.
What I have accomplished so far: I succesfully converted depth frame - thanks to the PCL Wrapper https://github.com/IntelRealSense/librealsense/tree/master/wrappers/pcl librealsense/wrappers/pcl at master · IntelRealSense/librealsense · GitHub
This is how I am accesing XYZ values of points - so the depth values
p.x = ptr->x;
p.y = ptr->y;
p.z = ptr->z;
Where p is pcl::PointCloud object and ptr is pointing to rs2::points.get_vertices(). Also I know I can access the RGB values just like XYZ, so p.r and so.
So what my greatest "wish" is - is to provide solution for me ( ) and of course for the others - maybe contribute to PCL wrapper in librealsense library - so the depth and color data from RS cameras would be easily convertible to PCD format. I am developing on Ubuntu.
I know how depth data is stored, at least I think I understand it - XYZ values of a single point are the coordinates (in meters), where [0,0,0] point is the camera base.
Little bit of background of my work, if you are interested. I am willing to create 3D map by registering a number of pointcloud datasets (frames). I would like to do this on the keypoints principle, that means I would like to apply SIFT algorithm - that is why I need to know correspondence between XYZ and RGB values of points in the pointcloud.
EMráz
So I am Replying to my own question, which was answered on Git ( https://github.com/IntelRealSense/librealsense/issues/1939 https://github.com/IntelRealSense/librealsense/issues/1939 )
So, the problem in baptiste-mnh solution was basically in exchanging two lines:
auto points = pc.calculate(depth);
pc.map_to(colored_frame);
To:
It is described in the Git issue posted above.
So here is the full working code, it may be considered like PCL wrapper for RealSense supporting XYZ + RGB conversion - https://github.com/eMrazSVK/JetsonSLAM/blob/master/pcl_testing.cpp https://github.com/eMrazSVK/JetsonSLAM/blob/master/pcl_testing.cpp
Thanks everyone for your help!
MartyG
Somebody who was trying to do a conversion to PCD used the sample program you linked to for the conversion and then saved it with this line:
pcl::io::savePCDFile(filename+".pcd", * cloud);
https://github.com/IntelRealSense/librealsense/issues/1455 Export an organized point cloud · Issue # 1455 · IntelRealSense/librealsense · GitHub
EMráz
Thank you for replying,
Saving of the Point Cloud is not a problem, I know how to save it. Function points_to_pcl(points) converts only XYZ values, not RGB. I need to find out, how I can align RGB values to Depth frame.
MartyG
Here's how someone did the PCL conversion for RGB:
https://github.com/IntelRealSense/librealsense/issues/1143 Generate a colorized PCL point cloud · Issue # 1143 · IntelRealSense/librealsense · GitHub
BMana
Hi!
You can try this !
typedef pcl::PointXYZRGB P_pcl;
typedef pcl::PointCloud<<span style="color: # b9bcd1;">P_pcl> point_cloud;
typedef point_cloud::Ptr ptr_cloud;
std::tuple<<span style="color: # b9bcd1;">uint8_t, uint8_t, uint8_t> get_texcolor(rs2::video_frame texture, rs2::texture_coordinate texcoords)
const int w = texture.get_width(), h = texture.get_height();
int x = std::min(std::max(int(texcoords.u*w + .5f), 0), w - 1);
int y = std::min(std::max(int(texcoords.v*h + .5f), 0), h - 1);
int idx = x * texture.get_bytes_per_pixel() + y * texture.get_stride_in_bytes();
const auto texture_data = reinterpret_cast<<span style="color: # cc7832; font-weight: bold;">const uint8_t*>(texture.get_data());
return std::tuple<<span style="color: # b9bcd1;">uint8_t, uint8_t, uint8_t>(
texture_data[idx], texture_data[idx + 1], texture_data[idx + 2]);
ptr_cloud points_to_pcl(const rs2::points& points, const rs2::video_frame& color){
ptr_cloud cloud(new point_cloud);
auto sp = points.get_profile().as<<span style="color: # b5b6e3;">rs2::video_stream_profile>();
cloud->width = static_cast<<span style="color: # b9bcd1;">uint32_t>(sp.width());
cloud->height = static_cast<<span style="color: # b9bcd1;">uint32_t>(sp.height());
cloud-><span style="color: # 9373a5;"...
MartyG
Thanks so much for your help with this question!
BMana
The sources if you need more infos : https://github.com/IntelRealSense/librealsense/issues/1601 Obtaining RGB values fora colorised PCL point cloud. · Issue # 1601 · IntelRealSense/librealsense · GitHub
You can mark the answer as resolved if it works!
EMráz
Thanks for the code, I have found it before, but the pointcloud is single-colored somehow. I will post info tomorrow. I appreciate your help, thanks again!
BMana
The code that I post above works with the good colors
EMráz
Hello again,
So I will post here my code - all points have the same color, I cannot tell why. I replaced pcl::io::savePCDFileBinary with pcl::io::savePCDFileASCII. So I can see the values through text editor. Every point has RGB value of 4283717469. This is the code: https://github.com/eMrazSVK/JetsonSLAM/blob/master/pcl_testing.cpp JetsonSLAM/pcl_testing.cpp at master · eMrazSVK/JetsonSLAM · GitHub
You can also take a look at the CMakeLists.txt, but I think it is all right so far. If any additional info would help, just let me know, I will post it.
Thank you.
EDIT: MartyG sorry, I unmarked the question as answered, because it did not solve the problem for me for now.
MartyG
No worries, taking off the Answered marking is the right thing to do if you need further assistance.
EMráz
To:
BMana
Oh, you answer one of my issues
When I was exporting .ply, the first one wasn't colored but the next ones were colored. I think it's because I inversed those lines!
