Items with no label
3341 Discussions
CreateActiveConfiguration();  doesn't work.
mniiz1
Hello all.
・camera :SR-300
・language : C#
・SDK :R3
I'm just getting started with my first RealSense project with SR-300 + C# and I'm trying to make simple program of hand detection.
Everytime I try to get a hand configration parameter by calling "CreateActiveConfiguration();" ,
however, null is returned as a result. the expected result is the HandConfiguration instance
I'm developing a C# project and The code is as shown below.
this error occuerd the point of ★★.
// initialize hand detection
private void InitializeHandTracking()
// getting hand detector
handAnalyzer = senseManager.QueryHand();
if ( handAnalyzer == null ) {
throw new Exception( "fail" );
// creating data of hand
handData = handAnalyzer.CreateOutput();
if ( handData == null ) {
// setting a property if the camera is RealSense
var device = senseManager.QueryCaptureManager().QueryDevice();
PXCMCapture.DeviceInfo dinfo;
device.QueryDeviceInfo( out dinfo );
if ( dinfo.model == PXCMCapture.DeviceModel.DEVICE_MODEL_SR300 ) {
device.SetDepthConfidenceThreshold( 1 );
device.SetIVCAMFilterOption( 6 );
// ★★setting hand detection configrarion★★
var config = handAnalyzer.CreateActiveConfiguration();
config.EnableSegmentationImage( true );
config.ApplyChanges();
config.Update();
Does anyone have a suggestion what I'm doing wrong?
Thanks a lot
MartyG
In the '2016 R3' SDK, the SDK was split into a range of different modules instead of everything being in a singe SDK package like it was in the previous '2016 R2' SDK. To get hand tracking functionality in R3, there are two stages:
1. Install the 'Essentials' core module.
2. Install the optional 'Full Hand Tracking and Gesture Recognition' module from the SDK download page.
https://software.intel.com/en-us/realsense-sdk-windows-eol Intel® RealSense™ SDK for Windows (Discontinued) | Intel® Software
May I ask please if you have installed the optional hand tracking module once the Essentials module was installed?
mniiz1
Thank you for your reply.
Yes, I already installed "https://registrationcenter.intel.com/en/forms/?productid=2801 Full Hand Tracking and Gesture Recognition ", and "'Essentials' core module" .
Do I need other setting??
Thanks!
MartyG
Based on analysis of other C# hand tracking scripts, it seems that the problem may be with defining the config variable as a var type of variable. A more common structure is to define it as a PXCMHandConfiguration type instead. For example:
PXCMHandConfiguration config = handAnalyzer.CreateActiveConfiguration();
mniiz1
Thank you for your quick help.
I tried to replace variable type to PXCMHandConfiguration from var.
but no change.
is there any thing can I do?
MartyG
A RealSense script in the old R2 and R3 SDKs should have this instruction at the very end of it.
sm.ReleaseFrame();
mniiz1
Ah, yes I already put "ReleaseFrame()"
but no change
Thank you for your help.
Hello realsenseUser001,
Thanks for your interest in the Intel® RealSense Technology.
The PXCMHandConfiguration type is from SDK R2 as seen here:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?doc_hand_initializing_and_configuring.html.
If you are using R3 of the SDK, then you should use HandConfiguration as described here:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v2016r3/documentation/html/index.html?doc_hand_initializing_and_configuring.html.
Refer to the hands viewer sample at C:\Program Files (x86)\Intel\RSSDK\sample\hand\HandsViewer.cs, for more information.
We hope you find this information helpful. If you need further assistance please do not hesitate to contact us again.
Josh B.
Intel Customer Support
