Items with no label
3341 Discussions
Creating the simplest program with RSSDK
MWalz1
Dear Intel® RealSense Community,
One week ago I posted /message/516093# 516093 this here at the forum. But then I noticed, that I should better start with the simplest program which can be created: I am trying to initialize the RSSDK, listing all devices, select the probably best device, capture a single frame and then release everything. Unfortunately, it seems that I do not understand yet how all this is working. So I wrote this console application here:
# include "stdafx.h"
# include
# include
# include "include/streaming.h"
# include "pxcsensemanager.h"
# include "pxccapturemanager.h"
# include "pxccapture.h"
# include "pxcimage.h"
# include
# include
using namespace std;
static const int NPROFILES_MAX = 100;
static const int NDEVICES_MAX = 100;
static const int IDC_STATUS = 10000;
static const int ID_DEVICEX = 21000;
static const int ID_STREAM1X = 22000;
static const int IDXM_DEVICE = 0;
static const int IDXM_MODE = 1;
static const int IDXM_SYNC = 2;
int main()
// Create a PXCSession instance
PXCSession *session = PXCSession::CreateInstance();
// Create a PXCSenseManager instance
PXCSenseManager *sm = PXCSenseManager::CreateInstance();
// Create a PXCCaptureManager instance
PXCCaptureManager *cm = sm->QueryCaptureManager();
// Listing all devices to a map
PXCSession::ImplDesc desc_template = {};
desc_template.group = PXCSession::IMPL_GROUP_SENSOR;
desc_template.subgroup = PXCSession::IMPL_SUBGROUP_VIDEO_CAPTURE;
std::map devices;
if (session) {
for (int m = 0, iitem = 0;; m++) {
std::cout << m;
PXCSession::ImplDesc desc_return;
if (session->QueryImpl(&desc_template, m, &desc_return) < PXC_STATUS_NO_ERROR) break;
PXCCapture *capture = 0;
if (session->CreateImpl(&desc_return, &capture) < PXC_STATUS_NO_ERROR) continue;
for (int j = 0;; j++) {
PXCCapture::DeviceInfo dinfo;
if (capture->QueryDeviceInfo(j, &dinfo) < PXC_STATUS_NO_ERROR) break;
int id = ID_DEVICEX + (iitem++)*NDEVICES_MAX + j;
devices[id] = desc_return.iuid;
pxcCHAR devName[128];
memset(devName, 0, 128 * sizeof(pxcCHAR));
capture->Release();
// device is a PXCCapture::Device instance
PXCCapture::Device *device = cm->QueryDevice();
PXCCapture* capture = cm->QueryCapture();
//do something with a captured single frame
//release all sessions
cm->Release();
sm->Release();
session->Release();
return 0;
Maybe you could correct my code and put some comments in it? I know I should use the camera in a separated thread, but for simplification I want to keep it as easy as possible.
On my Laptop there are two cameras available: an integrated webcam and the R200. My program should automatically identify the R200 and select it as a source camera. Is this possible?
By the way: As an orientation I used RSSDK Sample "Raw Streams (C++)" which was delivered with the installation.
Thank you a lot for your support!
Martin
------------ EDIT 1 ------------
I think it would be great if my program would provide these features:
  1. list all available devices in console
  2. select a device (user input)
  3. list all available modes
  4. select a mode (user input)
  5. capture a single frame
  6. display this picture or safe it to a file
  7. close the application
https://stackoverflow.com/questions/32174076/how-to-save-an-image-in-intel-realsensevisual-c Here I found a function to safe a picture as a BMP-file. Maybe you can help me on my way to achieve this?
------------ EDIT 2 ------------
Now I am able to capture a simple stream from the R200 camera and save this to a file:
const pxcCHAR *file = L"record.rssdk"; //filename for the record
cm->SetFileName(file, true); //true = record false = playback
sm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, 640, 480, 0);
// Initialize and Record 300 frames
sm->Init();
for (int i = 0; i<300; i++) {
// This function blocks until a color sample is ready
if (sm->AcquireFrame(true)
WriteToConsole("Capture frame...");
// Retrieve the sample
PXCCapture::Sample *sample = sm->QuerySample();
// Work on the image sample->color
// Go fetching the next sample
sm->ReleaseFrame();
But I still want to select the device and the mode by hand to make sure I understand the complete camera setup. This will make it easier for me to create further applications.
Hello Martin89,
Thanks for contacting Intel customer support.
We are investigating on your question, as soon as we have any information we will let you know.
Juan N.
MWalz1
Hi Juan,
Maybe you could explain to me how this function is working?
Because now when I try to query a device for both RGB and Depth, no device is available. Even though I can see the camera in Windows' device tree. So how is it querying its device? And how can I ensure that it will query the R200? Before I was querying Depth stream it worked fine and it selected the R200 automatically.
Thank you a lot!
Martin
In case that my source code helps, here it is at my current version:
# include
# include
# include
# include
# include
# include
# include
static const int ResColor_X = 0;
static const int ResColor_Y = 0;
static const int ResDepth_X = 0;
static const int ResDepth_Y = 0;
void WriteToConsole(const char *txt)
std::cout << string((std::string(txt)) + " \n");
int main()
PXCSenseManager *sm = session->CreateSenseManager();
if (sm) {
WriteToConsole("SessionManager created successfully!");
else {
WriteToConsole("Intitializing SessionManager failed!");
WriteToConsole("Abort!");
return 0;
if (cm) {
WriteToConsole("CaptureManager created successfully!");
else {
WriteToConsole("Intitializing CaptureManager failed!");
return 0;
WriteToConsole("");
// Query device
if (device) {
WriteToConsole("Device queried successfully!");
else {
WriteToConsole("Querying Device failed!");
return 0;
WriteToConsole("");
// Setup coordinate system
PXCSession::CoordinateSystem cs = session->QueryCoordinateSystem();
session->SetCoordinateSystem(PXCSession::COORDINATE_SYSTEM_FRONT_DEFAULT); // Z(camera) = X(robot's world) | X(camera) = Y(robot's world) | Y(camera) = Z(robot's world)
// select the color stream of size X*Y and depth stream of size X*Y
sm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, ResColor_X, ResColor_Y);
sm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, ResDepth_X, ResDepth_Y);
PXCImage::ImageData data_color;
PXCImage::ImageData data_depth;
WriteToConsole("Initialize...");
sm->Init();
WriteToConsole("Acquire frame...");
if (sm->AcquireFrame(true) < PXC_STATUS_NO_ERROR)
WriteToConsole("Error while acquireing Frame...");
break;
WriteToConsole("Capturing frame...");
PXCImage *colorImg = sample->color;
PXCImage *depthImg = sample->depth;
WriteToConsole("Acquire access...");
colorImg->AcquireAccess(PXCImage::ACCESS_READ_WRITE, PXCImage::PIXEL_FORMAT_RGB24, &data_color);
depthImg->AcquireAccess(PXCImage::ACCESS_READ_WRITE, &data_depth);
// render the frame
//if (!renderColor->RenderFrame(colorImg)) break;
//if (!renderDepth->RenderFrame(depthImg)) break;
// Create the PXCProjection instance.
WriteToConsole("Creating projection...");
PXCProjection *projection = device->CreateProjection();
// color and depth image size.
WriteToConsole("Querying Image Info...");
PXCImage::ImageInfo cinfo = colorImg->QueryInfo();
PXCImage::ImageInfo dinfo = depthImg->QueryInfo();
// Calculate the map.
WriteToConsole("Calculating map...");
//PXCPointF32 *uvmap = new PXCPointF32[dinfo.width*dinfo.height];
PXCPoint3DF32 *Camera_XYZmap = new PXCPoint3DF32[dinfo.width*dinfo.height];
PXCPoint3DF32 *World_XYZmap = new PXCPoint3DF32[dinfo.width*dinfo.height];
//projection->QueryUVMap(depthImg, uvmap);
projection->QueryVertices(depthImg, Camera_XYZmap);
projection->ProjectDepthToCamera((dinfo.width*dinfo.height), Camera_XYZmap, World_XYZmap);
// Translate depth points uv[] to color ij[]
/*for (int i = 0; i<(dinfo.width*dinfo...
MWalz1
Hello Intel® RealSense Community,
Is there really nobody who knows how the RSSDK is querying a device? Or did I just post a stupid question, because I am not a fulltime software developer? Maybe someone knows a workaround to avoid the "QueryDevice()"-function for my use case?
Martin
Hello Martin89,
I apologize for the delay. Through the community we do not check or correct your code. Checking and correcting codes is out of the scope of this community.
Regarding a sample code or example to assist you with your development it would be recommended for you to check the DF_CameraViewer sample (in the following link) here you will find useful information for your development.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/sample_camera_viewer_cpp.html
Again I apologize for the delay in answering your question, thanks for your understanding.
Juan N.
