Items with no label
3340 Discussions
D400 Series power consumption
PSnip
New Contributor II
I referred to the "Power Requirements" Table under D400-Series Datasheet. It says VCC Nominal 5V, and Max current of 700 mA. So I assume power consumption could be as high has 3500 mW. I believe under different usage conditions, actual power consumed may be less, e.g. while not using the Laser. Also another table in datasheet mentions that default Laser power consumption is 240 mW. And it is selectable from 0-360 mW in steps of 30mW. So, even when the Laser is completely turned off the consumption can still be 3140 mW?
These numbers are still in stark contrast w.r.t. what "Kinect for Azure" brief says, "225-950mW". Can some one point out what are typical power consumption numbers on D400 series, in particular I am interested in D415 with Laser On. If D400 series consumption is indeed manifolds that of Kinect, can some one confirm that it is mainly due to on board D4 vision processor. I believe that the individual cameras won't consume more than about 100 mW each, so it should be primarily the D4 Vision Processor?
MartyG
Given that the D4 board is powered by USB, and the D4 in turn passes on power to the depth module, use of the D4 board's power consumption as a guide to the general power consumption of the camera seems reasonable.
Jesus G from Intel support said in February that compared to the older SR300 camera model that lacks the D4 Vision Processor, the 400 Series draws less power at higher resolutions.
https://github.com/IntelRealSense/librealsense/issues/1172 Power consumption · Issue # 1172 · IntelRealSense/librealsense · GitHub
