Items with no label
3341 Discussions
D415 IR Projector Pattern
ASriv7
Where can I find more details about the IR projector pattern the D415 uses? Page 34 of the datasheet just mentions that the pattern type is static.
MartyG
A YouTube video shows the D415's dot pattern at 1:40.
https://m.youtube.com/watch?v=iY8ggcmcxqo https://m.youtube.com/watch?v=iY8ggcmcxqo
ASriv7
Thanks. We too were able to observe the diamond-shaped pattern in the RealSense Viewer, but we require more information about how the pattern is implemented (like does it change with distance, tilt, rounded objects, motion, etc.). Is this available somewhere in the source code maybe?
MartyG
I carefully researched your question but was unable to find information that would answer it. Hopefully an Intel support team member will be able to assist you. Good luck!
Hello Leponzo,
The pattern does not change depending on the scene or object. It is not implemented in source code. What specific information do you need about the pattern?
Juan N.
