Items with no label
3341 Discussions
D415 REC error - unknown cause
RVC
Hi all,
After 2 months of using several D415 (doing just fine), 4 out of 10 started failing. We get a 'Hardware notification: REC Error (...)' in the RealSense viewer. See screenshot.
As you can see:
  • USB3.1 is used (and detected! so cable = OK).
  • Resolution is low so there should not be a data overflow.
  • RGB works fine.
  • Depth image gives random stuff.
Extra info:
  • Structured light LEDs are flickering as usual.
  • Camera does not feel like it's overheating or anything
  • Above screenshot is 1 camera directly connected to computer via original USB cable!
Setup:
NUC7i5: 16GB RAM + 256GB SSD
11x Intel D415, via 3xUSB 3.0 hubs (4-port), externally powered. Worked fine without data overflow (low res).
What could be the issue? How can get more info in the error?
(Wishful thinking: could updating the firmware to latest version help? Is this calibration-related?)
Thanks!
MartyG
Could you try lowering the FPS from 30 to 15 please and see if the REC error still occurs.
RVC
Hi MartyG,
thanks for your input! This made no difference -however, apparently updating the firmware to v5.10.3 did help. I hope the issue stays resolved this way.
The strange thing is that we had no problems in the 2 prior months of testing?
Sorry for the big thread with an apparently easy solution. As long as this can help others or the further development it was not worthless though :-)
MartyG
You're very welcome! I was asking about the FPS reduction because when there are 'USB REC' type errors, a reduction in resolution or FPS usually fixes it. And you could not go lower in terms of resolution.
If you have problems in the future, especially when using multiple cameras, a user in the past with a multi-cam setup (up to 4 cameras) found that they could run their application for long periods if they used an industrial-grade USB hub.
