Items with no label
3341 Discussions
D415 camera getshot
BBoot
D415 camera get hot after 30-60 minutes of us when powered by Up-Board Squared Pentium Quad 4GB. Happens when Up Board is powered by 110 converter/5v6a. I've used different up board and direct Intel cameras - same results. Plan on trying 5v3a converter but concerned if Up Board will function properly. Any suggestions?
MartyG
The official power adapter with supplied country change plugs in the Up Store is 5v 4A. So it does sound like you might be cooking the Up Board with a 6A adapter. Coincidentally, I read someone saying yesterday about electrical maintenance on live wires, "It's not the volts that kills you, it's the amps"
https://up-shop.org/up-peripherals/65-dc-power-adapter-for-up-board-eu-plug.html https://up-shop.org/up-peripherals/65-dc-power-adapter-for-up-board-eu-plug.html
