Items with no label
3340 Discussions
D415 cannot be detected after switch of python interpreter
DDD
I already succeeded in connecting in python 2.7.15 and 3.6.0 for a while. However, after I reinstalled the python interpreter, it did not work anymore. Then I tried on another PC, at first it worked in python 3.6.0 well, then I reinstalled the open3d through cmake, it did not work either. Both report following error:
And I tested with the realsense viewer and python 2.7, both of them worked. So the cam should be OK.
Anyone knows what caused the issue? Thanks
Hello AronBroklyn,
Thank you for your interest in the Intel RealSense D415 Camera.
Can you try the files installed with https://github.com/IntelRealSense/librealsense/releases/download/v2.12.0/Intel.RealSense.SDK.exe Intel.RealSense.SDK.exe? Under we provide x86 and x64 versions for both python 2.7 and 3.6.
You will need to look at your Python paths and ensure that your Python code can find the RealSense dlls, and pyd files.
You can put those files in the same directory as where your python script is or where the Python path points to.
The following github post might prove useful: https://github.com/IntelRealSense/librealsense/issues/1877
Let me know if this works.
Casandra
Hello AronBroklyn,
Casandra
DDD
Hi Casandra, thanks for the reply. I just tried again, and it start to work in python 3.6 now for exactly the same code (I did nothing) . So I think the post might not be my issue.
I don't know whether it is common, but it actually happened on two of my PC, so it might worth attention
Hello AronBroklyn,
Thank you for your reply.
Is everything working now, according to your use needs?
Is there anything else I can assist you with?
Casandra
