Items with no label
3340 Discussions
D435, D415 weight
JHawt1
Am seeing if I can attach the D435 or D415 to a small drone capable of lifting about 150 grams (~5.29 oz) and I cant find any weight information on these 2 products.
Can anyone tell me how much the D415 and D435 weigh?
cheers.
MartyG
Both models are listed as weighing 72 grams.
MartyG
JHawt1
Thank you, Is it possible to remove the plastic housing and reduce the weight?
MartyG
The cameras also come in a caseless Module Kit version without the casing. So it should be possible to remove the case to reduce weight.
MartyG
I should add though of course that if you take the casing off a D415 or D435, you will instantly invalidate its sales warranty, making it ineligible to be returned.
JHawt1
