Items with no label
3340 Discussions
D435 camera :no depth data received
mzhou1
i connect the D435 camera to PC(windows 7), install the realsense sdk 2.0, open the intel realsense viewer(win 7), it works fine ,i can see both depth and rgb image, the i open the example program; there is a hello-world program:
using namespace rs2;
void main()
// Create a Pipeline, which serves as a top-level API for streaming and processing frames
pipeline p;
// Configure and start the pipeline
p.start();
while (true)
// Block program until frames arrive
frameset frames = p.wait_for_frames();
// Try to get a frame of a depth image
depth_frame depth = frames.get_depth_frame();
// The frameset might not contain a depth frame, if so continue until it does
if (!depth) continue;
// Get the depth frame's dimensions
float width = depth.get_width();
float height = depth.get_height();
// Query the distance from the camera to the object in the center of the image
float dist_to_center = depth.get_distance(width / 2, height / 2);
// Print the distance
std::cout << "The camera is facing an object " << dist_to_center << " meters away \r";
the depth is always NULL, the program cannot output the distance value;
then i open the realsense viewer, it show usb cam overflow.
why is that?
Did i miss something, or config the vs studio? i am using vs 2015 community version.
MartyG
Does the example program work if you run it without having opened the RealSense Viewer beforehand, please?
mzhou1
no, the example program does not work if the realsense viewer didnot open beforehand.
even i restart my computer, then run the example, no data received.
Hi Michael,
Have you tried running any of the C or C++ examples included in the SDK? The code you provided is just a code snippet and isn't meant to be a full program. The rs-distance example uses the code snippet above in a full program.
Sahira
mzhou1
this is a example code included in sdk, i open the program though the shortcut in desktop.
Hi Michael,
Just to be clear, only the hello-world example does not work? Have you tried the other examples from the SDK?
Sahira
_xct
Are you sure you're using usb3 port AND usb3 cable? Otherwise, you're in for a myriad of issues.
