Items with no label
3340 Discussions
D435 loses "Infrared 2" streams after 05.09.13.00->05.09.14.00
NSeme
Hi, could you please check 05.09.14 FW for regressions. I see `Infrared 2` streams again after a few wasted hours & downgrade to 05.09.13 FW.
Here's `rs-enumerate-devices` output for the same device connected to the same USB port. Please note `Usb Type Descriptor` 3.2 vs 2.1 changes.
Device info:
Name : Intel RealSense D435
Serial Number : XXX
Firmware Version : 05.09.14.00
Recommended Firmware Version : 05.09.14.00
Physical Port : /sys/devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13.4/3-13.4.2/3-13.4.2:1.0/video4linux/video1
Debug Op Code : 15
Advanced Mode : YES
Product Id : 0B07
Usb Type Descriptor : 2.1
Stream Profiles supported by Stereo Module
Supported modes: stream resolution fps format
Infrared 1 1280x720 @ 6Hz Y8
Infrared 1 1280x720 @ 4Hz Y8
Infrared 1 640x480 @ 30Hz Y8
Infrared 1 640x480 @ 15Hz Y8
Infrared 1 640x480 @ 6Hz Y8
Infrared 1 640x480 @ 4Hz Y8
Infrared 1 480x270 @ 60Hz Y8
Infrared 1 480x270 @ 30Hz Y8
Infrared 1 480x270 @ 15Hz Y8
Infrared 1 480x270 @ 6Hz Y8
Infrared 1 480x270 @ 4Hz Y8
Depth 1280x720 @ 6Hz Z16
Depth 1280x720 @ 4Hz Z16
Depth 640x480 @ 30Hz Z16
Depth 640x480 @ 15Hz Z16
Depth 640x480 @ 6Hz Z16
Depth 640x480 @ 4Hz Z16
Depth 480x270 @ 60Hz Z16
Depth 480x270 @ 30Hz Z16
Depth 480x270 @ 15Hz Z16
Depth 480x270 @ 6Hz Z16
Depth 480x270 @ 4Hz Z16
Stream Profiles supported by RGB Camera
Color 1280x720 @ 6Hz RGB8
Color 1280x720 @ 6Hz Y16
Color 1280x720 @ 6Hz BGRA8
Color 1280x720 @ 6Hz RGBA8
Color 1280x720 @ 6Hz BGR8
Color 1280x720 @ 6Hz YUYV
Color 640x480 @ 30Hz RGB8
Color 640x480 @ 30Hz Y16
Color 640x480 @ 30Hz BGRA8
Color 640x480 @ 30Hz RGBA8
Color 640x480 @ 30Hz BGR8
Color 640x480 @ 30Hz YUYV
Color 640x480 @ 15Hz RGB8
Color 640x480 @ 15Hz Y16
Color 640x480 @ 15Hz BGRA8
Color 640x480 @ 15Hz RGBA8
Color 640x480 @ 15Hz BGR8
Color 640x480 @ 15Hz YUYV
<span styl...
NSeme
The issue is gone after flashing 05.09.13.00 -> 05.09.11.00 -> 05.09.13.00 -> 05.09.14.00 and rebooting workstation.
MartyG
Awesome, thank you very much for the update. Have a great day
