Items with no label
3341 Discussions
D435 stops sending images when using opencv
JKjel1
I'm trying to use the D435 camera to get color images and opencv to work with it. I'm having problems reading the image. This is the python code I'm using:
import cv2   cap = cv2.VideoCapture(6) while (1==1): key=cv2.waitKey(1) ret, frame = cap.read() if ret: cv2.imshow("res",frame) if key==ord('q'): break cap.release() cv2.destroyAllWindows()
When run the code I get 2 color images which are all green and after those 2 I get the error message: python vidioc_dqbuf resource temporarily unavailable and no more images.
The scrip works with another camera, which isn't a d435. I've tried 2 different D435s and they both give the same faulty responses. When I use the same cameras and same python script on another computer it works. I'm positive the d435 is connected to a usb 3. Any help I can get is appreciated.
JKjel1
Eliza_D_Intel
Hello JKjel1, Thank you for your interest in the Intel RealSense D435 camera. I am unable to run this code. Could you please perhaps attach the source file in order for us to test it? Thank you, Eliza
Eliza_D_Intel
Hello JKjel1, We would like to know if you require further assistance on this topic. Thank you, Eliza
JKjel1
Solved the problem by using the sdk.
CDuon
I got the same issues. normally, I can read the realsense camera by opencv. But today, the green color is shown, and ​after 3 times reading the messages is "VIDIOC_DQBUF: Resource temporarily unavailable"
​Code:
import cv2 import numpy as np   # Create a VideoCapture object and read from input file # If the input is the camera, pass 0 instead of the video file name cap = cv2.VideoCapture(2) print('hello') # Check if camera opened successfully if (cap.isOpened()== False): print("Error opening video stream or file")   # Read until video is completed while(cap.isOpened()): # Capture frame-by-frame ret, frame = cap.read() if ret == True: print("can reading file") # Display the resulting frame cv2.imshow('Frame',frame)   # Press Q on keyboard to exit if cv2.waitKey(25) & 0xFF == ord('q'): break   # Break the loop else: break   # When everything done, release the video capture object cap.release()   # Closes all the frames cv2.destroyAllWindows()
Terminal result:
hello   can reading file   can reading file   can reading file   select timeout   VIDIOC_DQBUF: Resource temporarily unavailable
I already test the same code with others computer, it can work. I also change different realsense cameras, but the same results. :(
CDuon
annyway, the SDk still works. And the code is here. But I really want to figure out the problem in opencv
## License: Apache 2.0. See LICENSE file in root directory. ## Copyright(c) 2015-2017 Intel Corporation. All Rights Reserved.   ############################################### ## Open CV and Numpy integration ## ###############################################   import pyrealsense2 as rs import numpy as np import cv2     cv2.namedWindow('RealSense', cv2.WINDOW_AUTOSIZE)   # Configure depth and color streams pipeline = rs.pipeline() config = rs.config() config.enable_stream(rs.stream.depth, 640, 480, rs.format.z16, 30) config.enable_stream(rs.stream.color, 640, 480, rs.format.bgr8, 30)   # Start streaming pipeline.start(config)   try: while True:   # Wait for a coherent pair of frames: depth and color frames = pipeline.wait_for_frames() depth_frame = frames.get_depth_frame() color_frame = frames.get_color_frame() if not depth_frame or not color_frame: continue   # Convert images to numpy arrays depth_image = np.asanyarray(depth_frame.get_data()) color_image = np.asanyarray(color_frame.get_data())   # Apply colormap on depth image (image must be converted to 8-bit per pixel first) scaled_depth=cv2.convertScaleAbs(depth_image, alpha=0.08) depth_colormap = cv2.applyColorMap(scaled_depth, cv2.COLORMAP_JET)   # Stack both images horizontally images = np.hstack((color_image, depth_colormap))   # Show images cv2.imshow('RealSense', images)     k = cv2.waitKey(1) & 0xFF if k == 27: break   finally:   # Stop streaming pipeline.stop()
​References: http://robotsforroboticists.com/realsense-usage-robotics-slam/
