Items with no label
3340 Discussions
Depth Array of 640x480 in mm from SR300
KDhal
How do I get depth array from SR300 without any UI. I want a depth array in 30fps. What C++ code should I use?? And What header files are required to run that C++ code ??
Kashish Dhal
MartyG
If you are using the RealSense SDK in Windows then you could use this instruction to project world coordinates to the depth coordinates:
ProjecttCameraToDepth
Or use this instruction to project depth coordinates to the world coordinates.
ProjectDepthToCamera
You can set your stream to 640x480 resolution with:
sm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, 640, 480, 30);
The values 640, 480 of course refer to a resolution of 640x480, whilst the third value in the sequence (30) sets the FPS of the stream.
Below is a discussion that has a script for ProjectDepthToCamera that has headers in it. This may be a useful guide.
If you are using the Librealsense SDK instead of the RealSense SDK then you could use this instruction:
RS_STREAM_COLOR_ALIGNED_TO_DEPTH
