Items with no label
3341 Discussions
Depth Precision of D415
ASriv7
What is the depth precision of the D415 camera (i.e. what is the minimum depth change I can observe)? I'm not sure where this value is mentioned in the specifications.
MartyG
Officially the error range of the 400 Series cameras is 1% or less. In practice, it may vary depending on how close or far the camera is to what it is observing. For example, depth measuring accuracy may reduce when observing objects at a distance of 3 meters or more.
Depth accuracy may also reduce if you use a resolution lower than 848x400.
At close range, you can try altering the scaling factor of the camera to get the best results.
ASriv7
Thank you!
The post you linked suggests that the minimum depth change that can be detected is 1 mm (e.g. I can detect, say, breathing movements up to 1 mm). Is this value mentioned somewhere official?
MartyG
I do not have knowledge of documentation regarding the measuring of changes in depth.
ASriv7
I think this is what we need:
"The default scale of a D400 device is one millimeter, allowing for a maximum expressive range of ~65 meters. The depth scale can be modified by calling rs2_set_option(...) with RS2_OPTION_DEPTH_UNITS, which specifies the number of metres per one increment of depth. 0.001 would indicate millimeter scale, while 0.01 would indicate centimeter scale."
https://github.com/IntelRealSense/librealsense/wiki/Projection-in-RealSense-SDK-2.0 https://github.com/IntelRealSense/librealsense/wiki/Projection-in-RealSense-SDK-2.0
