Items with no label
3341 Discussions
Depth of a Pixel
MAlde3
What is the correct way of reading the depth of individual pixels in C++?
I want to copy depth matrix (without colorizing) to an OpenCV Mat and then make calculations with it.
MartyG
Are you using RealSense SDK 2.0 or the older '2016 R2' or '2016 R3' RealSense SDK, please?
MAlde3
I am using RealSense SDK 2.0 on a RS300, which will be replaced with D435
MartyG
Here's some C++ code for getting pixel depth in meters in SDK 2.0.
rs2::depth_frame dpt_frame = frame.as();
float pixel_distance_in_meters = dpt_frame.get_distance(x,y);
MAlde3
is there a way of getting distance values for all pixels at once?
MartyG
I wonder if a Point Cloud would be a suitable way for you to get all depth points at the same time.
https://github.com/IntelRealSense/librealsense/tree/master/examples/pointcloud librealsense/examples/pointcloud at master · IntelRealSense/librealsense · GitHub
You can also get a point cloud in the RealSense Viewer software by clicking on the '3D' option next to '2D' in the top corner of the Viewer program when a stream is playing.
MAlde3
I need the depth of every pixel for calculations in OpenCV. It will be running on an embedded device with Ubuntu, so Realsense Viewer is not an option.
MartyG
rs2_deproject_pixel_to_point may do the job. Deprojection takes a 2D pixel location on a stream's images, as well as a depth, specified in meters, and maps it to a 3D point location within the stream's associated 3D coordinate space.
https://github.com/IntelRealSense/librealsense/issues/1413 deprojection pixels to 3d point · Issue # 1413 · IntelRealSense/librealsense · GitHub
You may also be interested in a pre-made depth program for OpenCV by developer UnaNancyOwen.
https://github.com/UnaNancyOwen/RealSense2Sample/tree/master/sample/Depth RealSense2Sample/sample/Depth at master · UnaNancyOwen/RealSense2Sample · GitHub
JRomu
I have done it this way;
Quote
float darray [480 * 640];
int main()
//Contruct a pipeline which abstracts the device
rs2::pipeline pipe;
//Create a configuration for configuring the pipeline with a non default profile
rs2::config cfg;
//Add desired streams to configuration
cfg.enable_stream(RS2_STREAM_COLOR, 640, 480, RS2_FORMAT_BGR8, 15);
cfg.enable_stream(RS2_STREAM_INFRARED, 640, 480, RS2_FORMAT_Y8, 15);
cfg.enable_stream(RS2_STREAM_DEPTH, 640, 480, RS2_FORMAT_Z16, 15);
//Instruct pipeline to start streaming with the requested configuration
pipe.start(cfg);
namedWindow("Colour", WINDOW_AUTOSIZE); namedWindow("IR", WINDOW_AUTOSIZE);
while (1) {
rs2::frameset frames;
//Wait for all configured streams to produce a frame
frames = pipe.wait_for_frames();
// Try to get a frame of a depth image
rs2::depth_frame d = frames.get_depth_frame();
// darray contains distance meters of all the x,y
for (int j = 0; j < 480; j++)
for (int i = 0; i< 640; i++)
darray[i + (j * 640)]= d.get_distance(i, j);
//Get each frame
rs2::frame color_frame = frames.get_color_frame();
rs2::frame ir_frame = frames.first(RS2_STREAM_INFRARED);
// Creating OpenCV Matrix from a color image
Mat color(Size(640, 480), CV_8UC3, (void*)color_frame.get_data(), Mat::AUTO_STEP);
Mat ir(Size(640, 480), CV_8UC1, (void*)ir_frame.get_data(), Mat::AUTO_STEP);
// Display in a GUI
imshow("Colour", color); imshow("IR", ir);
char key = waitKey(30);
if (key == 27) {
cout << "key pressed" << endl;
color.release(); ir.release();
break;
destroyAllWindows();
return 0;
Unquote
MartyG
Awesome, thanks so much for sharing your script with the community, JJR
