Items with no label
3341 Discussions
Different frame rates and resolutions.
PBoos
I'd like to suggest different frame dimensions and frame rates.
I dont know if this is possible for the hardware, but it would be nice if it could run higher framerates and orcustom dimension sizes reduce of frames, to reduce transmitted data size.
ea, less pixels to send, means less pixels to process allowing us to use more advanced algorithms.
So we would be able to spend more time on image processing and less on data retrieval.
If possible to have that for all camera modus ea, Color, Infrared 1, Infrared2, and Depth (IR1 and IR2 combined).
Hello IndustrialPeter,
Thank you for your contacting Intel® RealSense™ support.
For future references, your ticket number is 03397475. Please keep this number handy in case you are asked for it.
We appreciate you recommendations and feedback regarding our Intel® RealSense™ Technology; we will provide this information to the department in charge of the development to be considered for future updates.
We would like to know if you need further assistance or if we can close this case.
Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one, unless your inquiry is completely unrelated. This way we will prevent generating duplicate post or case numbers and we will not lose the train of thought.
Josh B.
Intel Customer Support
PBoos
no need for further assistance regarding to this topic, thanks
Thank you for your reply, as per your consent, this case is now closed.
If you need further assistance please do not hesitate to contact us.
Josh B.
