Items with no label
3341 Discussions
Downgrade RealSense Firmware
AObei
I have a RealSense D435 with the newest 5.9.14 firmware. I was wondering if it possible to downgrade to an older firmware? Does this pose a risk on the camera hardware itself or is it safe? Could I just run an "upgrade" with an older version?
Thanks for the help.
MartyG
You can downgrade the firmware up to 20 times, after which the camera will only allow a newer firmware version than the one that is currently installed. I would advise against downgrading too far because you will re-introduce problems with the camera that were corrected in recent firmware updates. So I would advise only going a few versions back at the most.
There is not anything in the previous firmware versions that would break the camera but as mentioned above, you may experience degraded performance or be more vulnerable to certain problems fixed in newer firmwares.
MartyG
AObei
Oh okay never knew they had it limited as well! Thanks for your help Marty!
Vibhu-Bithar
Whats the process for downgrading the firmware? and where can i get the old firmware files
Vibhu-Bithar
So much fun to answer your own questions
1st : got to https://downloadcenter.intel.com/product/190004/Intel-RealSense-Depth-Camera-D435i
2nd: download the firmware version you want and extract the files
3rd : use realsense-viewer to upload firmware
Done
MKing15
Hello there, wondering if there is a downgrade tool available to do this or any info on how to downgrade.
Much appreciated, Melinda
