Items with no label
3341 Discussions
Euclid can't connect with my wifi.
wHsu8
i am useing euclid
i can find EUCLID_xxxx with my laptop and operate it' by web interface ,it's work
but when i want to useing ubuntu and i need to connect to my home wifi
but it's seems always auto useing hotspot and i can't useing it connect to my home wifi
i try to stop EUCLID_xxxx this network but still can't
can anyone help? thx alot
Hi UUilliamHsu,
We understand that you're having an issue where you can't connect your Euclid device to your home network using Ubuntu. Based on page 15 of the https://click.intel.com/media/productid2100_10052017/euclid-operating-guide-final.pdf Operating https://click.intel.com/media/productid2100_10052017/euclid-operating-guide-final.pdf guide you must use the web interface in order to connect Euclid to another network, so try to connect to the hotspot and then once connected look for the WiFi settings tab and scan for your home network. After scanning for networks, your's should appear and it should allow you to connect.
Let us know in case you need further assistance.
Leonardo L
Hi UUilliamHsu,
We are writing to follow up on your thread, let us know if the recommendations from the reply worked for you or if you still need assistance with your Euclid device, we'll be looking forward to your reply.
Leonardo L
