Items with no label
3341 Discussions
F200 on I5 Gen 1 Intel with Renesas USB3 win10
PHB
After some help on the sample apps.
Hardware
Sony Vaio Gen1 I5 M520 proc, 16gb, $8 dx.com expresscard Renesas USB 3.0 eXtensible Host Controller - 1.0 (Microsoft),10.0.10586.212
F200 XYZ3d Scanner - latest firmware. Software latest DCM and SDK as of 1/2/2017.
(Bugger off Intel. I worked around their installers intentionally looking for Intel gear)
Can run *most* of the sample exes from the SDK, all guns blazing (Depth, IR and RGB). Can scan to obj. view all channels and play about.
I have a problem with visual studio run times.
Related to the 2005 studio software from previous win 7 install - just win10'd over top.
If I uninstall visual studio 2005, the samples all crash, even if remove and re-install latest sdk & modules.
Want to know what are required Vis studio/VB/Vc# /Vc++ run times that should be installed to make all this work correctly?
I force over vcredist_x86_v140.exe but makes no difference. Are there environment variables that need to be set?
The facial recognition bombs out due to some path error, everything else seems perfectly fine.
PHB
Replying to myself.. https://software.intel.com/en-us/forums/intel-perceptual-computing-sdk/topic/391249 Errors Compiling Samples - libpxccamera_mf.dll buffer overflow. hmm
Hi Pyp,
Thank you for contacting us.
I'm wondering if your reply to your original post answered your question or if you still have questions regarding this case.
Also, I would like to let you know that while you're using your RealSense camera without any major issues, your current hardware doesn't meet the requirements to use the F200 camera. A 4rd Generation Intel Core CPU is needed for these cameras to work correctly. And even if your current issue doesn't seem to be related to compatibility, this might be a problem in the future, so please keep this in mind.
-Pablo
PHB
I would appreciate furter understanding of the runtimes required.
I completely rebuilt my development environment and reinstalled just windows and all updates,USB and graphic drivers, DCM, SDK minimum camera runs but install any other module and get above error.
Does not appear to be hardware related as I can get all channels all resolution at all frame rates for the camera.
Hi Pyp,
I've never had this issue before, so I'm not sure what might be causing the problem with the runtimes. However, I've never tried to use the SDK or any RealSense Camera with Visual Studio 2005 installed on my PC or with two versions of the software installed.
I did find some links that might contain some useful information about it, I would recommend you to read them.
http://www.howtogeek.com/256245/why-are-there-so-many-microsoft-visual-c-redistributables-installed-on-my-pc/ http://www.howtogeek.com/256245/why-are-there-so-many-microsoft-visual-c-redistributables-installed-on-my-pc/
https://docs.oracle.com/cd/E14688_01/e1tools898pbr1/eng/psbooks/1tsw/chapter.htm?File=1tsw/htm/1tsw16.htm https://docs.oracle.com/cd/E14688_01/e1tools898pbr1/eng/psbooks/1tsw/chapter.htm?File=1tsw/htm/1tsw16.htm
-Pablo
Hi Pyp,
Do you have updates on this case?
-Pablo
PHB
Was SDK installer problem, after rebuilding win10 a second time, reinstall first and latest sdk, on another old laptop, check found env variable and reg not correctly set, installer problem.
Slow but it works fine.
Anywhere to get R200 etc in Australia?
