Items with no label
3341 Discussions
Hello, What is the best way to calculate the equation of the floor plane in a scene?
RTang10
So that I can measure the the distance normal to the plane to a point which would be height.
At the moment I am taking 3 points by clicking positions in the image and taking the world coordinates and calculating the equation of a plane.
 However this is very unreliable and inaccurate, is there something I am missing?
Eliza_D_Intel
Hello RTang10, Thank you for your interest in the Intel RealSense Technology. You can check out the opencv example DNN - https://github.com/IntelRealSense/librealsense/tree/master/wrappers/opencv/dnn This example will calculate approximate distance to an object using the depth data. Thank you and best regards, Eliza
Eliza_D_Intel
Eliza_D_Intel
Hello RTang10, We would like to know if you require further assistance on this topic. Thank you, Eliza
RTang10
Hello Eliza, thank you so much for your help,
The link provided was a little bit useful however I managed to find another solution to the problem by using the difference of y coordinates to get the height.
Ray
