Items with no label
3340 Discussions
Hi, is there any Android SDK to connect Realsense depth camera D435 to an Android Device?
MChar21
I currently work in a project where we must connect an Intel D435 depth camera to an Android device.The Android application waits for the frames from the camera and do some calculations (like distance,objects detection ...)
INTEL can support the development of applications running in Android devices?
Eliza_D_Intel
Hello Marios,
Intel RealSense SDK 2.0 (librealsense) is a platform developed and supported by Intel. The first link I have provided contains the official guide on how to connect Android device with RealSense D400 cameras.
The second link I have provided contains a pull request that have been tested and confirmed to work by RealSense users. An official guide for non-rooted Android devices have not yet been released.
On https://github.com/IntelRealSense/librealsense/issues/2746 RealSense Team informed that they are planning to publish a version for non-rooted devices, but we do not have a release date yet.
Thank you and best regards,
Eliza
Eliza_D_Intel
Hello MChar21, Thank you for your interest in the Intel RealSense D435 camera. Yes, you can begin by checking this page from Librealsense: https://github.com/IntelRealSense/librealsense/blob/a321a0404c7b0cfd2e157d85c6b00f88a3e55d48/doc/android/AndroidJavaApp.md where it is described how to build an android application for RealSense SDK. Thank you and best regards, Eliza
MChar21
Hi again,
I have a question about the development Android Applications for Intel RealSense D435 depth camera as proposed in the link:
Why is necessary to install Android Studio for Linux and not for Windows?
Thanks in advance,
Marios
MChar21
Thanks for your answer.
But for non root Android devices,is there any support?
Best Regards
Marios Charalambides
Eliza_D_Intel
Hello Marios, You can check this pull request from Librealsense Github page for non-rooted Android phones: https://github.com/IntelRealSense/librealsense/pull/2822 Thank you and best regards, Eliza
MChar21
Thanks you again , but INTEL which one of these solutions support?
The second one (for non root devices ) is stable?
Has any one used this solution?
Which one is the best?
Thanks in advance
Eliza_D_Intel
Hello Marios,
Eliza
MChar21
Thanks for the answer,
I hope the version for non-rooted devices will be available soon.
Best Regards
Marios
calebjones
That's an ambitious and cool project! Intel does support the use of the D435 camera on Android through their open-source RealSense SDK 2.0 (librealsense). You will need to use the Android wrapper provided within the SDK's GitHub repository to build your application in Android Studio. Ensure your Android device supports USB OTG for data transfer and power, which is the key to
