Items with no label
3340 Discussions
How can I retrieve the gain and exposure values for each frame?
LLits
I am using the realsense SDK 2.0 with the RealSense D435. The programming language is use is C++. I am trying to get the gain and exposure each time new frames are retrieved. I can however not find the commands to get these gain and exposure values. What command should I use to get these values? Thank you in advance for helping and I hope to hear from you soon.
MartyG
This link gives a script for getting the exposure values from metadata:
https://github.com/IntelRealSense/librealsense/issues/1624#issuecomment-389085387
You can read the official metadata documentation here, which also describes a metadata attribute called GAIN_LEVEL
https://github.com/IntelRealSense/librealsense/blob/master/doc/frame_metadata.md
The link below gives advice about controlling the gain and exposure values.
https://github.com/IntelRealSense/librealsense/issues/1663
MartyG
LLits
Thank you very much @MartyG​  for the quick answer I will give it a try!
