Items with no label
3340 Discussions
How can I use the depth camera of RS300 with MATLAB?
DAtia
When I try to open the depth camera with MATLAB, I get green image.
Is there a way to work with the depth camera in MATLAB?
MartyG
There is not much information on the RealSense forums about using the camera with MATLAB. RealSense expert Samontab's opinion was that a direct streaming of the camera data into MATLAB was not viable, and you should instead "use the RealSense SDK to get the correct depth value and export it into MATLAB."
https://software.intel.com/forums/realsense/topic/561647 Streaming Depth into Matlab
Intel support staff member Jesus Garcia's thoughts on the issue were that "The [RealSense] SDK team does not support Matlab integration." Which is another way of saying, I guess, that you need to export the data into MATLAB somehow. A support member on the MATLAB forum confirmed that - at the time of writing his message in October 2015 - that MATLAB did not yet support RealSense.
Here's a link to somebody else who had a green image when trying to stream a RealSense depth image into MATLAB.
http://stackoverflow.com/questions/33328675/how-do-i-interpret-an-intel-realsense-camera-depth-map-in-matlab How do I interpret an Intel Realsense camera depth map in MATLAB? - Stack Overflow
A developer on GitHub has apparently written an adapter to get MATLAB to work with RealSense streams, though it was written for the SR300's predecessor the F200 so I cannot guarantee it will work.
https://github.com/gameinskysky/RealSenseImaq GitHub - gameinskysky/RealSenseImaq: Real Sense Adaptor
SL4
I have managed to do it. Try to use "imaqtool" in matlab to get the depth data directly. If you use the function "imshow" to display one image directly, it may be too dark. Thus I try to multiplied by a constant 100 to show the image.
Here is my code.
% 2017-03-31 by LSS
clc; clear;
% vidDepth = imaq.VideoDevice('winvideo', 2);
% vidColor = imaq.VideoDevice('winvideo', 1, 'YUY2_640x480');
vidDepth = imaq.VideoDevice('winvideo', 1, 'Z16 _628x469');
vidColor = imaq.VideoDevice('winvideo', 2);
hVideoDepth = vision.VideoPlayer;
hVideoDepth.Name = 'depth';
hVideoColor = vision.VideoPlayer;
hVideoColor.Name = 'color';
nFrames = 0;
while (nFrames < 500)
DepthFrame = 100 * step(vidDepth);
step(hVideoDepth, DepthFrame);
step(hVideoColor, step(vidColor));
nFrames = nFrames + 1;
end
release(vidDepth);
release(vidColor);
release(hVideoDepth);
release(hVideoColor);
close all force;
fprintf('end\n');
MartyG
Awesome, thanks so much for sharing your experience and your script
