Hi everyone,
We are trying to use the temporal filter and the high accuracy visual preset by code with the D435 RealSense camera but we can not modify this options.
Using the realsense-viewer both the visual present and the temporal filter options are modified correctly. The problem appears when modifing them by code, the value is modified but the difference is not appreciated in the depth output.
This is the code that we are using:
#include <librealsense2/rs.hpp>
#include <opencv2/opencv.hpp>
int main(int argc, char const *argv[])
rs2::temporal_filter filter;
filter.set_option(RS2_OPTION_FRAMES_QUEUE_SIZE, 16);
filter.set_option(RS2_OPTION_FILTER_SMOOTH_ALPHA, 0.07);
filter.set_option(RS2_OPTION_FILTER_SMOOTH_DELTA, 88);
filter.set_option(RS2_OPTION_HOLES_FILL, 8);
std::vector<rs2_option> supported = filter.get_supported_options();
for (rs2_option opt : supported){
std::cout << filter.get_option_name(opt) << " (" << filter.get_option_description(opt) << "): " << filter.get_option(opt) << std::endl;
rs2::option_range rangeF = filter.get_option_range(opt);
for (int i = rangeF.min; i <= rangeF.max; i = i + rangeF.step){
auto des = filter.get_option_value_description(opt, i);
if(NULL != des){
std::cout << " " << i << ": " << des << std::endl;
}else{
break;
//Create a context
rs2::context ctx;
auto list = ctx.query_devices();
rs2::device device = list.front(); // Get a snapshot of currently connected devices
std::vector<rs2::sensor> sensors = device.query_sensors();
rs2::sensor sensor = sensors[0]; //0 : Stereo Module
// To set an option to a different value, we can call set_option with a new value
try
sensor.set_option(RS2_OPTION_VISUAL_PRESET, 3); //3: High Accuracy
catch (const rs2::error& e)
// Some options can only be set while the camera is streaming,
// and generally the hardware might fail so it is good practice to catch exceptions from set_option
std::cerr << "Failed to set option " << RS2_OPTION_VISUAL_PRESET << ". (" << e.what() << ")" << std::endl;
rs2::config cfg;
cfg.enable_device(device.get_info(RS2_CAMERA_INFO_SERIAL_NUMBER));
rs2::pipeline pipe;
rs2::pipeline_profile profile = pipe.start(cfg);
std::cout << "Pipeline started" << std::endl;
rs2::frameset frames;
rs2::frame depth;
rs2::colorizer color_map;
bool is_capturing = true;
while(is_capturing){
try{
frames = pipe.wait_for_frames();
//use frames here
depth = frames.get_depth_frame();
int width = depth.as<rs2::video_frame>().get_width();
int height = depth.as<rs2::video_frame>().get_height();
//Create OpenCV matrix of size (w,h) from the colorized depth data
rs2::frame colorized_depth = color_map.process(depth);
cv::Mat color_image(cv::Size(width, height), CV_8UC3, (void*)colorized_depth.get_data(), cv::Mat::AUTO_STEP);
cv::cvtColor(color_image, color_image, CV_BGR2RGB);
cv::imshow("Depth", color_image);
rs2::frame filtered = depth;
filtered = filter.process(filtered);
rs2::frame colorized_filtered = color_map.process(filtered);
width = filtered.as<rs2::video_frame>().get_width();
height = filtered.as<rs2::video_frame>().get_height();
cv::Mat filter_image(cv::Size(width, height), CV_8UC3, (void*)colorized_filtered.get_data(), cv::Mat::AUTO_STEP);
cv::cvtColor(filter_image, filter_image, CV_BGR2RGB);
cv::imshow("Filtered depth", filter_image);
cv::waitKey(1);
}catch(rs2::error e){
is_capturing = false;
std::cout << "Stop capturing" << std::endl;
pipe.stop();
return 0;
}How can we modify the options by code?
Thank you
Hello Eliza,
I have applied the modifications specified in the issue that you comment but the problem persists. The temporal filter is applied, there is a difference between the original depth and the filtered one. The problem is that even though I modify the filter options (smooth alpha, smooth delta and temporal persistence) the filtered result is always the same.
Original depth frame (without post-processing):
RealSense Viewer:
Temporal filter with smooth delta = 18 (left) and Temporal filter with smooth delta = 88 (right)
Own code:
The same happens with the visual preset, even though I modify the sensor value, the depth frame is exactly the same.
RealSense Viewer:
Default preset (left) and High accuracy (right)
Own code:
What can I do to solve the problem?
Thank you,
Xènia
Hello Eliza,
There is no difference with this new code, the depth stills unchanged.
Thank you,
Xènia
Hello Eliza,
Do you have any idea about the problem that we have? Can we try any other modification to solve the problem?
Thank you,
Xènia
Hello Jesus,
I have been able to solve the problem related with the high accuracy preset. The solution was to use the following code instead of the set_option function:
if(device.is<rs400::advanced_mode>()){
auto advanced_mode_dev = device.as<rs400::advanced_mode>();
if(!advanced_mode_dev.is_enabled()){
advanced_mode_dev.toggle_advanced_mode(true);
std::ifstream t("highAccuracy.json");
std::string str((std::istreambuf_iterator<char>(t)), std::istreambuf_iterator<char>());
advanced_mode_dev.load_json(str);
}Where the highAccuracy.json file is obtained using the RealSense Viewer.
The problem with the temporal filter is still unsolved.
Thank you,
Xènia
Hello Jesus,
This is what I am expecting. The problem is that even if I change the temporal filter options, the filtered result is always the same.
Xènia
