Items with no label
3341 Discussions
How do you export usable depth data and use it in another program?
APrat2
I am using the SR300 and C++ and i am trying to save the depth data(straight mm values) generated by the camera and be able to use it in another program. I have been able to save the raw stream in the .rssdk format, but there is not much you can do with that, i would like to get it in a .csv or any other file type that contains the data in an easily accessible way. I have tried everything I can find and nothing seems to work for me.
Any advice would be greatly appreciated. Thank you.
MartyG
Some developers have used OpenCV to convert RealSense data to a .mat format file. Example:
https://software.intel.com/en-us/forums/realsense/topic/538066 Use openCV with Intel Realsense SDK
Hello prattal,
I was wondering if you could check the suggestion provided by MartyG.
If you have any update or question, don't hesitate to contact us.
Andres V.
jzhan57
Hi,MartyG
I use the 2016R3 sdk, where there is not a PXCImage. It seems that PXCImage has been replaced by Image. I do not know what the 'planes' and 'pitches' meaning in the structure of ImageData?
MartyG
A good starting point may be the R3 documentation's entry for Image, if you haven't been there already, as it redirects there when clicking on the PXCImage link.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v2016r3/documentation/html/index.html?pxcimage.html Intel® RealSense™ SDK 2016 R3 Documentation
