Items with no label
3341 Discussions
How to access the UART on Euclid?
CLiu36
I tried `find /dev/tty*`, which doesn't seems to show any port looks like uart.
Any suggestions?
MPall2
Here's what worked.
Used the following items.
https://www.sparkfun.com/products/10031 SparkFun USB MicroB Plug Breakout - BOB-10031 - SparkFun Electronics
https://www.adafruit.com/product/954 https://www.adafruit.com/product/954
TX out of USB UART (Green) -> D-
RX into USB UART (White)-> D+
GND of USB UART (Black)-> GND
Don't connect Vcc.
Terminal settings -115200/8/N/1
Hi Chang1,
Thank you for getting in contact, let's see if we can help you.
Which port of the device are you using to connect to UART? Could you please show us a picture of your UART connection?
Pablo M.
Amit_M_Intel
It should be /dev/ttyS0.
can you try?
thanks,
Amit
CLiu36
Hi Pablo and Amit,
Thank you very much for your reply.
As shown in the image, I am trying to access the UART port at the bottom of Euclid, which is a micro USB port labeled as 'UART'.
I assume if I cut the usb cable, I can directly access the UART.
Before testing the /dev/ttyS0, I need to confirm the pin-out of the UART, and the voltage level it is operating (5V? 3.3V? 1.8V?). do not want to fry it.
I couldn't find any information on this.
Thank you very much for your time.
Kind Regards,
Chang
Hi Chang,
Some other users have also asked for this information, so we are already looking into it. We are waiting for the details from our HW engineer, so we would really appreciate your patience in the meantime.
Pablo M.
Bo_J_Intel
You can use a UART-USB cable to access this debug UART port. It is for kernel log output by default.The pin out definition is {VCC, TX, RX, NC, GND}, VCC is 3.3V.
We bought the cable from the following link. Pls pay attention that the default pin out is not correct (TX and RX are inversed). So remember to tell the vendor about the correct pin out you need.
https://world.taobao.com/item/6302450202.htm?fromSite=main&_u=e27u36ua0bce https://world.taobao.com/item/6302450202.htm?fromSite=main&_u=e27u36ua0bce
聪马1
These are the connector types used in Euclid:
- UART connector info: Manufacturer: JAE, Part number: DX4R005HJ5
- Power adapter plate interface info: Pogo pins, Pin outs: PAD1---+VBATTERY, PAD2---BATT_ID, PAD3---BATT_GND
And this is the pinout for Euclid's power adapter:
/servlet/JiveServlet/showImage/2-482259-379133/Euclid Power Adapter PinOut.png
Pablo M.
MPall2
Here's what worked.
Don't connect Vcc.
