Items with no label
3341 Discussions
How to align depth to color from a d435 depth camera on matlab?
EAlta
I have the depth and color frames of a d435 depth camera on matlab.
How can I align depth image to color image (or viceversa) on matlab?
There is a file named "align.m" on github but I dont understand how to use the function.
Hello edgar.altamirano,
Thank you for your interest in the Intel RealSense D435 camera.
The SDK offers a processing block for aligning the image to one another, producing a set of frames that share the same resolution and allow for easy mapping of pixels.
For more information, you can access the link below
https://github.com/IntelRealSense/librealsense/wiki/Projection-in-RealSense-SDK-2.0%23frame-alignment https://github.com/IntelRealSense/librealsense/wiki/Projection-in-RealSense-SDK-2.0# frame-alignment
You can also check out the following community threads:
/message/558305# 558305 https://communities.intel.com/message/558305# 558305
/thread/129107 https://communities.intel.com/thread/129107
Let me know if this information proves useful or if there is anything else I can assist you with.
Casandra
EAlta
Thanks for your time.
1) I do want to align depth and color frames as mentioned on the community threads you suggested me to check; but I need to do it using Matlab.
There is an align function on matlabs wrapper (https://github.com/IntelRealSense/librealsense/tree/master/wrappers/matlab librealsense/wrappers/matlab at master · IntelRealSense/librealsense · GitHub ) but there is no example on how to it.......could you help me with this?
2) Do depth and color frames have to have the same resolution to make the alignment?
Ali996
@EAlta Have you got answer to your question?
