Items with no label
3340 Discussions
How to apply visual presets in C++
DSolo2
I am trying to change the visual preset on the D415 using the example code given in but it does not seem to be working. When I run the code, there is no effect on the stream. If I use the Realsense Viewer tool to change the presets, then it works. I am running Windows 10.
Is there a step that I am missing?
MartyG
Are you trying to change the resolution and / or FPS at start-up, please? If so, these particular settings cannot currently be set with a json for reasons explained in the link below.
MartyG
DSolo2
Yes, I am setting the FPS and resolution at start up. I will try your suggestion and report the result. Many thanks for your helpful response MartyG.
DSolo2
I was able to make the preset take effect by first saving it to JSON using realsense viewer and then loading the preset using the code in your link.
Thank you for your help.
MartyG
Awesome, thanks for the tip about how you solved the problem in your project!
