Items with no label
3340 Discussions
How to correctly import pyrealsense2 in the RaspberryPi3 launcher?
lchen165
I want to use the D435 camera on the RaspberryPi3, but I have a problem.
when i want to automaticlly run a python program on RaspberryPi, i meet a error : no module named pyrealsense2.
but after the RaspberryPi3 starts, this program can correctly run .
the system of RaspberryPi3 is ubuntu16.04.
MartyG
Guidance on using Pyrealsense2 with the Raspbian OS can be found in the link below, if you have not already seen it.
https://github.com/IntelRealSense/librealsense/blob/master/doc/installation_raspbian.md
If you want to use Ubuntu 16.04 instead of Raspbian, you could try skipping to the Pyrealsense2 section of the instructions and see if you can apply them to Ubuntu.
https://github.com/IntelRealSense/librealsense/blob/master/doc/installation_raspbian.md#install-pyrealsense2
