Items with no label
3340 Discussions
How to iterate over pointcloud for color data
Andrew_Carluccio
I am attempting to access the color values of pixels from the RGB sensor with the goal of storing a few frames as "snapshots" in a bitmap format. Because there is no native .getColor() method available in the SDK like there is for depth, my reading has lead me to create a PCL pointcloud from aligned frames from which to extract RGB values point by point.
I do not understand how to iterate over the pointcloud so that a bitmap in (x,y) could be "colored in" with matching values from cloud->points[i] . How should I approach this next step?
Also, if there is an easier way to access pixel (x,y) from the RGB sensor, please let me know!
Andrew_Carluccio
It is probably a good idea to show exactly how I am creating the pointcloud:
pcl::PointCloud *points_to_pcl(const rs2::points& points, const rs2::video_frame& color){
pcl::PointCloud *cloud(new pcl::PointCloud);
auto sp = points.get_profile().as();
cloud->width = sp.width();
cloud->height = sp.height();
cloud->is_dense = false;
cloud->points.resize(points.size());
auto tex_coords = points.get_texture_coordinates();
auto vertices = points.get_vertices();
for (int i = 0; i < points.size(); ++i)
cloud->points[i].x = vertices[i].x;
cloud->points[i].y = vertices[i].y;
cloud->points[i].z = vertices[i].z;
std::tuple current_color;
current_color = get_texcolor(color, tex_coords[i]);
cloud->points[i].r = std::get<0>(current_color);
cloud->points[i].g = std::get<1>(current_color);
cloud->points[i].b = std::get<2>(current_color);
return cloud;
This is adapted from Yonatan-Sade's solution...
https://github.com/IntelRealSense/librealsense/issues/1601# issuecomment-387512731 https://github.com/IntelRealSense/librealsense/issues/1601# issuecomment-387512731
Andrew_Carluccio
So I realized in looking at that code more closely that I could skip the PCL entirely, so I am now running this:
//for reference, myFrame is an EasyBMP bitmap
void rsFrameManager::makeBitmap(const rs2::points& points, const rs2::video_frame& color){
int w = (tex_coords[i].u)*width;
int h = (tex_coords[i].v)*height;
myFrame(w, h)->Red = std::get<0>(current_color);
myFrame(w, h)->Green = std::get<1>(current_color);
myFrame(w, h)->Blue = std::get<2>(current_color);
myFrame(w, h)->Alpha = 0;
Unfortunately, when I print the resulting bitmap, it is just a white frame, so this still does not work, but I suspect this is a step towards my solution.
MartyG
The RealSense GitHub has a couple of discussions about getting RGB values from a colorized point cloud.
https://github.com/IntelRealSense/librealsense/issues/1601 Obtaining RGB values fora colorised PCL point cloud. · Issue # 1601 · IntelRealSense/librealsense · GitHub
https://github.com/IntelRealSense/librealsense/issues/1429 Can't get color of point · Issue # 1429 · IntelRealSense/librealsense · GitHub
Andrew_Carluccio
Thank you for the reply!
I was familiar with the first link you mentioned but not the second. I think I understand the solution used in the second link but am confused as to what color_intrinsic , used to calculate colorLocation, is and how I should calculate it on my end. How does color_intrinsic work?
EDIT:
I have defined color_intrinsic as
rs2_intrinsics color_intrinsic = colorFrame.get_profile().as().get_intrinsics();
which I believe is proper. Now I am just trying to figure out how to map the verticies to pixels in a BMP and set the colors accordingly. Suggestions?
MartyG
If you are mapping 3D XYZ vertices to 2D pixels, I believe that the appropriate instruction is rs2_project_point_to_pixel. There is a detailed discussion about it in the link below.
Andrew_Carluccio
Interesting. I was in a time crunch so I used writing to a .png and then converting to .bmp as a bandaid solution to get me up and running for my deadline, but obviously I want to replace that mechanism for performance reasons soon. I will take a look at rs2_project_point_to_pixel this weekend with hopes that it can resolve my current issue on the pointcloud side, where the resulting bitmap only consists of white pixels. I will update once I've gotten to play with this instruction.
