Items with no label
3341 Discussions
I use the RS depth camera 435 connecting to Android mobile device,using the Android wrapper. The Config.enableStream(StreamType type, int width, int height, StreamFormat format) method , what width and height values supports?
MChar21
Alexandru_O_Intel
Hello MChar21, Thank you for your interest in the Intel RealSense D435 camera. You can find the supported resolution for the the D435 camera in the datasheet, at page 54-55, Table 4-2 for USB 3.1 Gen1, and Table 4-3 for USB 2.0 - https://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-technology/Intel-RealSense-D400-Series-Datasheet.pdf Best regards, Alexandru
Alexandru_O_Intel
MartyG
I would expect the resolutions available to depend on whether your Android device supports USB 2 or USB 3 / USB 3 OTG (a USB 3 micro-port on mobile devices that can have ful USB 3 devices attached via an adapter). If it is a USB 2 device then the range of available resolutions will be much more limited than on a device with USB 3.
Pages 54 -56 of the current edition of the data sheet document for the RealSense 400 Series cameras list the formats, resolutions and FPS speeds available on USB 3 and USB 2.
https://www.intel.com/content/www/us/en/support/articles/000026827/emerging-technologies/intel-realsense-technology.html
Edit: it looks as though myself and Alexandru posted replies at the same time :)
Alexandru_O_Intel
Hello MChar21, Could you please let us know if you still require assistance on this topic? Best regards, Alexandru
