Items with no label
3341 Discussions
If I change the depth units, should I also change some distance parameter such as DistanceThreshold, HeightLimits, etc.
zting1
As the Question said, If I change the depth units, should I also change some distance parameter such as DistanceThreshold, HeightLimits, etc.
MartyG
I recommend reading the discussion linked to below from start to end, as it provides a lot of expert explanation from the RealSense SDK Manager and the RealSense Group's Chief Technical Officer about using the camera at very close range,
https://github.com/IntelRealSense/librealsense/issues/1171
MartyG
I'm not aware of a need to change the mentioned factors if the Depth Unit value is changed.
zting1
Sorry, Does that mean the depth units represent the accuracy of decimal
MartyG
