Items with no label
3335 Discussions
Intel D435 recording abilities on an independent support
CCaza1
I have another question and would like to know if D435 has video recording abilities independently of a computer
with the possibility to activate recording directly on the device (for example with an usb disk or a memory card to record),
or if the use of a computer is mandatory with a usb link to a computer ?
Many thanks for your help.
Best,
C.
Hello C,
Thanks for posting the RealSense community.
The use of a computer connected to the D435 and any other RealSense camera is a must.
The cameras no only use the computer as a storage for the captured images, the computer is also used as the only power source for the camera. Additionally you need the SDK 2.0 to be running in order for the camera to capture images.
In the following link you will find the camera datasheet with detailed technical information.
https://software.intel.com/en-us/realsense/d400/intel-realsense-depth-camera-d400-series-datasheet
Juan N.
