Items with no label
3341 Discussions
Intel Driver and Support assistant tells me "Sorry, something went wrong while trying to scan."
jbern28
where do I get details on where the error originates and how to correct it (I cant find a log)
AlHill
What is the model number of your NUC?
Doc
jbern28
sorry I may not be in the good forum category. I did not find a category that fit.
I have trouble with the "INtel Driver and Support Assistant" that scans your system and finds the drivers that need to be updated
What is the NUC ?
AlHill
A NUC is what you do not have - https://www.intel.com/content/www/us/en/products/boards-kits/nuc.html
Regarding IDSA, clear your browser cache.
Regarding logs, look in C:\ProgramData\Intel\DSA.
What anti-viruse and firewall are you using?
What version of W10? 1909?
What is your processor model number?
Doc
jbern28
sorry for this question on NUC.
I cleared cache again, nothing changes.
I am under W10 1909 Intel® Core™ i7-8700K CPU @ 3.70GHz
Windows firewall and antivirus
this DSA directory contains many files.
launching the IDSA creates/updates 9 of them including a ServiceHelper.log that says "exits with code 0".
the other files do not seem to contains logs but information of my computer Detailed-System-Report.html in particular
AlHill
look for
  • updateservice
  • servicehelper
  • tray
  • service
Put them in a zip file and attach it to this thread (using the paperclip). If you do not do a zip file, you will have to paste each one in a separate reply.
Doc
jbern28
here is the file
i do see errors but they are not making sense to me
jbern28
to make logs a little cleaner, I removed DSA application, deleted DSA folder, then reinstall.
still error
here are the new logs
Wanner_G_Intel
Hello jbern28,
Thank you for submitting your question on this Intel® Community.
Our team is investigating this issue. We will update this thread as soon as possible.
Wanner G.
Wanner_G_Intel
Hello jbern28,
Could you please provide us with all the files in the Intel® Driver & Support Assistant (Intel® DSA) log directory C:\ProgramData\Intel\DSA (XML and JSON).
Wanner G.
jbern28
Hi wannerG
I will be traveling away from home for the next 3 weeks. The problem is on my home computer and i can no longer access it.
When i am back i willl update wjndows, reinstall dsa and check if problem is still here
If it is i will post again.
Sorry for the delay​
Wanner_G_Intel
Hello jbern28,
We would like to keep this case open.
We will follow up on this issue in three weeks.
Feel free to reply back to this post as soon as you can.
Wanner G.
GRowe3
Hi
I have same issue for the last few weeks.
OS Name Microsoft Windows 10 Pro
Version 10.0.18363 Build 18363 (1909)
System Model OMEN by HP Laptop 17-cb0xxx
System Type x64-based PC
Processor Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz, 2592 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date AMI F.22, 9/12/2019
SMBIOS Version 3.2
Windows Directory C:\Windows
System Directory C:\Windows\system32
Installed Physical Memory (RAM) 16.0 GB
Total Virtual Memory 27.9 GB
Page File C:\pagefile.sys
Antivirus BitDefender
Firewall Windows
I have cleared browser cache and used both Chrome and Edge.
I have disabled AV.
I have disabled Domain, Private, and Public Firewalls.
I have uninstalled via Windows and reinstalled with latest Intel download.
I have uninstalled via Intel Uninstall utility and reinstalled with latest Intel download.
GRowe3
Forgot to state that the IDSA widget by the clock indicates there are 2 updates available.
MVats
I'm suddenly having the same issue with my copy. I've done exactly as GRowe3 has, and all I get is the same non-indicative error message that something has gone wrong.
YLEMO2
Exactly the same issue on 5 very different computers, with the 20.1.5.6 version of Intel DSA, same message in red "Sorry, something went wrong while trying to scan.".
This occurs on all my different browsers (Firefox, Edge, Google Chrome, Opera, Internet Explorer, ...) whatever their cache.
Installation of Intel DSA is OK, I have all the expected files in \ProgramData\Intel\DSA, I also tried the Intel uninstaller. before a new installation.
My hardware is fully recon (and detailed in "System-Report.html") ... and I can detect since yesterday a red point (it was green before) in the DSA icon of the taskbar, "one update" is mentioned.
I expect Intel's fellows to solve this problem very quickly, Regards from France 😁😁
YLEMO2
Needless to tell that a lot of previous versions of Intel DSA were 100% OK on all my computers.
As the program is obviously opening and scanning accurately PC's, I suspect some problems at the level of security/firewall, would it be linked to some recent updates of crosoft Win10 Prof 1909 (build 18363.657) ?
In the \ProgramData\Intel\DSA folder, I got an inf file (oemxxx.inf) for each of the Intel IGPU (s).
YLEMO2
my folder DSA...
GRowe3
As stated by my new French friend, IDSA worked flawlessly with previous versions.
NOkay
have the same problem 😕
Wanner_G_Intel
Hello all, please try the following steps and let us know if the issue persists:
1. Run the Intel® Driver & Support Assistant Uninstaller Version: 20.1.5.6
2. Restart and run the latest Intel® Driver & Support Assistant tool version 20.1.5.6
If the problem persists, please provide us with the following information:
A. The latest file from Intel® System Support Utility for Windows*
B. The latest Intel® Driver & Support Assistant Uninstaller log file: using File Explorer, search for DSAUninstaller.log
C. The latest Intel® Driver & Support Assistant log files: using File Explorer: go to folder = C:\ProgramData\Intel\DSA, and zip the Log files or entire folder.
Note: Uncheck Hide System files to see the AppData folder.
Show hidden files
https://support.microsoft.com/en-us/help/14201/windows-show-hidden-files
Wanner G.
