Items with no label
3341 Discussions
Intel RealSense 3D Camera driver not installed
mzio
Hello to everyone,
I've bought this :
http://click.intel.com/intel-realsense-developer-kit-r200.html Intel® RealSense™ Developer Kit for Tablets R200
I've attached it to a several USB 3.0 ports,I've installed the driver and the SDK from here :
https://downloadmirror.intel.com/25044/eng/intel_rs_dcm_r200_2.1.27.2853.exe https://downloadmirror.intel.com/25044/eng/intel_rs_dcm_r200_2.1.27.2853.exe
and finally,I've installed this game to try if it works :
https://downloadcenter.intel.com/it/download/24334/Warrior-Wave-Game-for-Intel-RealSense-Camera Download Sempre in movimento ondata gioco per la videocamera Intel ® RealSense ™
as soon as I start the game installation,it says :
intel realsense 3d camera driver not installed. But it is not true,because from the control panel everything seems to work correctly,check the attached pictures,thanks.
MartyG
The Warrior Wave game, which is the one that you installed, is for the F200 and RS-300 'desktop' cameras, whilst you are using the R200 'mobile' camera. They are not the same hardware. So the camera is likely working with no problem.
I'm afraid I could not find an alternative R200 program to test your camera with. Available applications seem to be mostly for the F200 and SR-300, as the R200 was designed for outdoor image processing rather than playing games with the hands and face like the desktop cams. I recommend trying one of the sample applications for the R200 in the Sample Browser application that comes packaged with the SDK. Usually the browser is installed to our desktop in a folder called 'Intel RealSense SDK Gold'. Good luck!
Aashutosh
Hello
I have a query related to the L515 camera. I am trying to use it with WSL2 Ubuntu 18.04.5 but it is not being recognized. Any suggestions on how to proceed ?
Thank you
Hi mario_zio,
Do you still need assistance with this case? Let us know if there's anything else we can help you with.
-Sergio
