Items with no label
3340 Discussions
Intel RealSense Depth Camera Manager Install Fails
MMaks3
Hi there,
I have just got the Intel RealSense SR300 camera. Whilst trying to install it I am greeted with this error message.
I have tried reinstalling my PC. I still get this error. I hope you can help.
Thank you in advance,
Maksim Richards
Jorge_I_Intel
Hi Maksim,
Can you share more information about your system?
Manufacturer
Model
CPU
OS
Using USB 3 port?
Also can you post the installation logs from %temp%\micl_tmp_%username%?
Jorge
MMaks3
Thanks for the quick reply. Here are my specs:
HP Z600
Intel Xeon X5570 (x2)
Windows 10 x64
USB 3.0 (From expansion PCI-E card)
Thank you.
Maksim
MMaks3
Sorry I forgot the logs. Here is the one from the .msi that is failing:
=== Verbose logging started: 29/04/2016 16:30:31 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\Users\maksi\AppData\Local\Temp\{80edc8d9-e292-4f73-b077-7e52b4a8fe42}\setup.exe ===
MSI (c) (74:8C) [16:30:31:492]: Resetting cached policy values
MSI (c) (74:8C) [16:30:31:492]: Machine policy value 'Debug' is 0
MSI (c) (74:8C) [16:30:31:492]: ******* RunEngine:
******* Product: C:\Users\maksi\AppData\Local\Temp\{80edc8d9-e292-4f73-b077-7e52b4a8fe42}\installs\intel_rs_sdk_runtime_ia32_dcmservice_sr300_3_1_25_2599.msi
******* Action:
******* CommandLine: **********
MSI (c) (74:8C) [16:30:31:492]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (74:8C) [16:30:31:492]: Grabbed execution mutex.
MSI (c) (74:8C) [16:30:31:492]: Cloaking enabled.
MSI (c) (74:8C) [16:30:31:492]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (74:8C) [16:30:31:492]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (1C:E4) [16:30:31:492]: Running installation inside multi-package transaction C:\Users\maksi\AppData\Local\Temp\{80edc8d9-e292-4f73-b077-7e52b4a8fe42}\installs\intel_rs_sdk_runtime_ia32_dcmservice_sr300_3_1_25_2599.msi
MSI (s) (1C:E4) [16:30:31:492]: Grabbed execution mutex.
MSI (s) (1C:F8) [16:30:31:492]: Resetting cached policy values
MSI (s) (1C:F8) [16:30:31:492]: Machine policy value 'Debug' is 0
MSI (s) (1C:F8) [16:30:31:492]: ******* RunEngine:
******* Action:
MSI (s) (1C:F8) [16:30:31:492]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (1C:F8) [16:30:31:492]: Note: 1: 2203 2: C:\Windows\Installer\inprogressinstallinfo.ipi 3: -2147287038
MSI (s) (1C:F8) [16:30:31:492]: SRSetRestorePoint skipped for this transaction.
MSI (s) (1C:F8) [16:30:31:492]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI (s) (1C:F8) [16:30:31:492]: File will have security applied from OpCode.
MSI (s) (1C:F8) [16:30:31:508]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\maksi\AppData\Local\Temp\{80edc8d9-e292-4f73-b077-7e52b4a8fe42}\installs\intel_rs_sdk_runtime_ia32_dcmservice_sr300_3_1_25_2599.msi' against software restriction policy
MSI (s) (1C:F8) [16:30:31:508]: SOFTWARE RESTRICTION POLICY: C:\Users\maksi\AppData\Local\Temp\{80edc8d9-e292-4f73-b077-7e52b4a8fe42}\installs\intel_rs_sdk_runtime_ia32_dcmservice_sr300_3_1_25_2599.msi has a digital signature
MSI (s) (1C:F8) [16:30:31:539]: SOFTWARE RESTRICTION POLICY: C:\Users\maksi\AppData\Local\Temp\{80edc8d9-e292-4f73-b077-7e52b4a8fe42}\installs\intel_rs_sdk_runtime_ia32_dcmservice_sr300_3_1_25_2599.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (1C:F8) [16:30:31:539]: MSCOREE not loaded loading copy from system32
MSI (s) (1C:F8) [16:30:31:539]: End dialog not enabled
MSI (s) (1C:F8) [16:30:31:539]: Original package ==> C:\Users\maksi\AppData\Local\Temp\{80edc8d9-e292-4f73-b077-7e52b4a8fe42}\installs\intel_rs_sdk_runtime_ia32_dcmservice_sr300_3_1_25_2599.msi
MSI (s) (1C:F8) [16:30:31:539]: Package we're running from ==> C:\Windows\Installer\adce2.msi
MSI (s) (1C:F8) [16:30:31:539]: APPCOMPAT: Compatibility mode property overrides found.
MSI (s) (1C:F8) [16:30:31:539]: APPCOMPAT: looking for appcompat database entry with ProductCode '{D78D858F-EB52-11E5-9A19-2C44FD873B55}'.
MSI (s) (1C:F8) [16:30:31:539]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (1C:F8) [16:30:31:539]: Machine policy value 'TransformsSecure' is 0
MSI (s) (1C:F8) [16:30:31:539]: User policy value 'TransformsAtSource' is 0
MSI (s) (1C:F8) [16:30:31:539]: Machine policy value 'DisablePatch' is 0
MSI (s) (1C:F8) [16:30:31:539]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (1C:F8) [16:30:31:539]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (1C:F8) [16:30:31:539]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (1C:F8) [16:30:31:539]: Transforms are not secure.
MSI (s) (1C:F8) [16:30:31:539]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\maksi\AppData\Local\Temp\micl_tmp_maksi\2016.04.29_16.30.13_00001674\log\intel_rs_sdk_runtime_ia32_dcmservice_sr300_3_1_25_2599.msi_{68ce9da9-41e4-4a42-b6bf-708ed8ca81a6}.log'.
MSI (s) (1C:F8) [16:30:31:539]: Command Line: INSTALLDIR=C:\Program Files (x86)\Common Files\Intel\RSDCM_SR300 ARPSYSTEMCOMPONENT=1 UNINSTALL_CMD=C:\ProgramData\Intel\installer\rs_sdk_2014\cache\2dc3e021-eb54-11e5-be42-2c44fd873b55\setup.exe UNINSTALL_CMD_ARGS=--product="dcm_runtime_sr300_3.1.25.2599" REBOOT=ReallySuppress EXTERNALUI=PSET CURRENTDIRECTORY=C:\Users\maksi\AppData\Local\Temp\{80edc8d9-e292-4f73-b077-7e52b4a8fe42} CLIENTUILEVEL=3 MSICLIENTUSESEXTERNALUI=1 CLIENTPROCESSID=5748
MSI (s) (1C:F8) [16:30:31:539]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{32A01B06-DDA2-462C-9DFC-BCEF155831AB}'.
MSI (s) (1C:F8) [16:30:31:539]: Product Code passed to Engine.Initialize: ''
MSI (s) (1C:F8) [16:30:31:539]: Product Code from property table before transforms: '{D78D858F-EB52-11E5-9A19-2C44FD873B55}'
MSI (s) (1C:F8) [16:30:31:539]: Product Code from property table after transforms: '{D78D858F-EB52-11E5-9A19-2C44FD873B55}'
MSI (s) (1C:F8) [16:30:31:539]: Product not registered: beginning first-time install
MSI (s) (1C:F8) [16:30:31:539]: Product {D78D858F-EB52-11E5-9A19-2C44FD873B55} is not managed.
MSI (s) (1C:F8) [16:30:31:539]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (1C:F8) [16:30:31:539]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (1C:F8) [16:30:31:539]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (1C:F8) [16:30:31:539]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (1C:F8) [...
Jorge_I_Intel
Hi Maksim,
Looks like you don't have the proper CPU.
You can go here: http://mark.intel.com/ http://mark.intel.com/ to find out the currently available 6th Generation Intel® Core™ Processors.
Jorge
MMaks3
Hi there,
I've tried the camera on a different computer which works fine. However that computer is a little Samsung notebook without an Intel 6th Generation Processor. Does it say in the log files that, that is what is causing the error because it looks like the .msi is failing not because of an incorrect processor.
Thank you,
Maksim
I'm sorry MaksimRichards but to support the bandwidth needed for the Intel RealSense camera, a powered USB 3.0 port is required on the client system. The SR300 camera requires Windows 10 and a 6th generation Intel® Core™ processor or later.
For details on system requirements and supported operating systems for SR300, visit the page https://software.intel.com/en-us/RealSense/Devkit https://software.intel.com/en-us/RealSense/Devkit
Ivan
