Items with no label
3341 Discussions
Intel RealSense d415 depth sensor stop working
MTont
HI, yesterday one of my camera just stop working. The RGB camera still working but the stereo module doesn't.
When I start the viewer, it show this message:
And then this is what I've got:
Is it fixable?
thank you!
MartyG
This problem occurred to somebody else a few weeks ago. An Intel support agent recommended looking at this forum link of a case with the same error on the same camera type (410 is a 415 type camera without an outer casing):
https://github.com/IntelRealSense/librealsense/issues/1508 410 Depth Module not being recognized · Issue # 1508 · IntelRealSense/librealsense · GitHub
Hello Lab,
Thank you for your interest in the Intel RealSense D415.
In order to resolve this issue, please download the calibration tool from: https://downloadcenter.intel.com/download/27415/%3Fv%3Dt https://downloadcenter.intel.com/download/27415/?v=t and then run the command: Intel.Realsense.CustomRW.exe -g
Please let us know if it's working!
Thank you,
Eliza
MTont
Thank you MartyG for the answer (As always )
@Intel Corporation
I downloaded the calibrator, but it's not clear for me where I've to run the command.
In the cmd.exe it says that it's not a right command.
MTont
Ok, I did it.
thi is the output:
"customRW for Intel RealSense D400, Version: 2.5.2.0
Calibration on device successfully reset to default gold factory settings."
but the problem remains...
MTont
Before I do that (I can't reboot my pc right now), This problem still exist in all my pc (linux and windows). It is definitely a device problem.
Should I do this procedure ( I can do that tomorrow...) or is there something else?
Hello Lab,
A couple of days ago we released a new version of the calibration tool that may fix your issue.
Download and install the Calibration Tool again and then run Intel.Realsense.CustomRW.exe -r and then send us the output - I attached a photo as an example. Run Intel.Realsense.CustomRW.exe -g to recover the calibration table.
Alexandra
Hello Lab,
Did you try installing the Calibration Tool again?
Alexandra
