I am trying to use the model trained with nvidia digits for object detection with a live feed. I am facing error. I heard only vl42 compliant devices work with jetson xavier(link to this post could be found below ).
Could you please let me know if this camera is vl42 compliant??
Thanks in advance
Hi sj000,
Thank you for your interest in the Intel RealSense D435i camera.
Linux build configuration is presently configured to use the V4L2 backend by default.
https://github.com/IntelRealSense/librealsense/blob/master/doc/installation.md#building-librealsense2-sdk
Be advised that Intel does not officially support the Jetson line of devices. Furthermore, there are several known issues with running librealsense on Jetson.
Alexandra
@sj000 I'd just like to add to this discussion that the JetsonHacks website has a guide to setting up the 400 Series cameras and Librealsense2 on Jetson AGX Xavier if you have not seen it already.
https://forums.intel.com/s/question/0D50P00004ElYrDSAV/guide-to-setting-up-librealsense2-on-jetson-agx-xavier-at-jetsonhacks
Thank you for the post. I followed Jetsonhacks article. However, on using the command,
v4l2-ctl --all
returns
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : Intel(R) RealSense(TM) Depth Ca
Bus info : usb-3610000.xhci-1
Driver version: 4.9.108
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 1280/720
Pixel Format : 'Z16 '
Field : None
Bytes per Line : 2560
Size Image : 1843200
Colorspace : Default
Transfer Function : Default (maps to Rec. 709)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1280, Height 720
Default : Left 0, Top 0, Width 1280, Height 720
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 1280, Height 720
Selection: crop_bounds, Left 0, Top 0, Width 1280, Height 720
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 30.000 (30/1)
Read buffers : 0
gain 0x00980913 (int) : min=16 max=248 step=1 default=16 value=16So is it right that only the depth data is received and not rgb?? Also please have a look at my post at nvidia: https://devtalk.nvidia.com/default/topic/1048157/jetson-agx-xavier/issue-in-connecting-camera-/
Please provide me with some information on possibilities to get rgb data on v4l2.
Hello Eliza,
Thank you for your post. It works with ./realsense-viewer. However the output from v4L is as above. Any idea on why is that so?? and how to get an output in the v4L??
BR
sJ000
Hello Eliza,
Thank you for the link but the case is different. My doubt is if the device is v4l2 compliant, what is the reason that there is no ouput with the command v4l2-ctl --all??
Best regards
sj000
