Items with no label
3341 Discussions
JavaScript Websocket problem
epano
i just installed realsense SDK 2016 R3 on new intel nuc skull canyon + new camera (SR300)
the JavaScript WS not working(c# and others work fine) :
https://192.55.233.1/resourceaccesstoken https://192.55.233.1/resourceaccesstoken
{"error":{"code":400,"errors":[{"domain":"CapabilityProxy","extendedHelp":"","message":"","reason":"CP-001","sendReport":""}],"message":"Invalid parameter received in request.","requestId":0}
https://192.55.233.1/health
{"data": {"kind": "healthcheck", "isHealthy": true, "name": "capabilityProxy", "build": "1008", "version": "1.9.1"}}
i try to reinstall ITA , websetup--> not working
http://davidslight.com/t/gesture.html RealSense Sample Gesture Detection App
this site return
Hosted version of Intel SDK Javascript sample:
Please download the latest runtime to run this app
MartyG
Java support and the Web Runtime have been removed from the R3 SDK onwards. Developers will need to download the previous R2 SDK to continue to use them.
From the "What's new and different in Intel RealSense SDK 2016 R3' post at the top of the forum front page:
"MW packages, such as Blob Tracking, Speech, Touchless Controller, RealSense Web Runtime, and Java support, have been deprecated and are only available in previous versions of the RealSense SDK."
epano
1. i try old ver of the sdk - not working.
2. i need JavaScript (web runtime + ITA)
3. did they update the camera firmware/driver and remove all of the Websocket contections ?
MartyG
I looked in the release notes document about the web runtime and fixing problems with it. It said:
Webapp runtime components from older releases cannot be installed if newer "Intel(R) Technology Access*" (ITA) version is installed. The recovery procedure is to:
Remove ITA
Install WebApp
Install latest ITA
Hi Eyalpano,
Thanks for your interest in the Intel® RealSense Technology.
We would like to know if you have tried MartyG's suggestions and if you are able to use web runtime + ITA, additionally, please let us know if you have any question.
-Yermi
epano
i try , it just don't work.
same
{"error":{"code":400,"errors":[{"domain":"CapabilityProxy","extendedHelp":"","message":"","reason":"CP-001","sendReport":""}],"message":"Invalid parameter received in request.","requestId":12}} from https://192.55.233.1/resourceaccesstoken https://192.55.233.1/resourceaccesstoken
i checked in my task manager->IntelTechnologyAccessService is running.
Hi Eyalpano,
We would like to know which SDK version you have installed, could you please let us know this? Here you can find the previous SDK versions: https://software.intel.com/en-us/articles/previous-intel-realsense-install Previous Intel® RealSense™ Install Software. Additionally, we'd suggest you to install the newest version of https://downloadcenter.intel.com/download/25435 ITA, and please take a look at this https://software.intel.com/en-us/forums/realsense/topic/625304 link, there you will find helpful information regarding this error.
Hope this information helps, also, we'll be waiting for your reply.
-Yermi
epano
  • Intel(R) RealSense(TM) SDK 10.0.26.396
  • Intel(R) RealSense(TM) Depth Camera Manager 1.4.27.52404
  • Intel(R) RealSense(TM) 3D Camera 2780
Update available at http://www.intel.com/realsense Intel Realsense Portal :
  • Intel(R) RealSense(TM) SDK 2014 Runtime Beta 6.0.21.6598
Hi Eyalpano,
Thanks for the information provided. Looking at that information we believe you are using an Intel RealSense F200 camera, is it correct? We are asking for it because the DCM you have shared is from that camera, you can check it here: https://downloadcenter.intel.com/download/25044/Intel-RealSense-Depth-Camera-Manager Intel® RealSense™ Depth Camera Manager, and in the first post you mentioned the SR300 camera.
Additionally, we would like to confirm some information. In the link shared in my previous post (https://software.intel.com/en-us/forums/realsense/topic/625304 link) some users have solved it by updating the ITA. Have you updated the ITA?
We'll be waiting for you reply.
-Yermi
epano
i try both of the cameras, with the update ITA -> same error.
i try all from the link - did't worked
Hi eyalpano,
Thanks for your reply. We would like to investigate a little bit more and as soon as we find useful information we'll let you know.
We appreciate your patience during the meantime.
-Yermi
Hi Eyalpano,
We would like to know if the Javascript samples work for you, on this path you can find them: C:\Program Files (x86)\Intel\RSSDK\framework \JavaScript\... We have tested the FF_Handsviewer Javascript sample and it worked with the latest ITA and RealSense SDK R2, we used the SR300 with the latest DCM.
Please try these examples and let us know your results.
-Yermi
epano
SDK and components versions:
  • Intel(R) RealSense(TM) Depth Camera Manager 1.4.27.32425
same problem ->
{"error":{"code":400,"errors":[{"domain":"CapabilityProxy","extendedHelp":"","message":"","reason":"CP-001","sendReport":""}],"message":"Invalid parameter received in request.","requestId":6}}
Hi Eyalpano,
Have you gotten that error message running a Javascript sample? We would like to know which samples you have tested and if any of them worked for you.
We are requesting this in order to identify the source of the issue and be able to further assist you properly. We will be awaiting for your response.
-Yermi
Hi Eyalpano,
We would like to know if you have tested the Javascript samples and if you have any updates.
-Yermi
MartyG
I did some research into the error and into the ITA. In a discussion thread commented on by Intel staffer Ricardog, it was stated that the ITA's function relates to PCs with touch screens such as '2 in 1' devices.
The purpose of the ITA is restated in this other post by Intel staffer Henry A.
Opinion was that if your PC does not use a touch device then the ITA can be uninstalled and left removed.
epano
i just try anything that's say's in the post (one after another) and it failed.
the javascript not working .
i try to download the app from the link in the sdk sample - (https://software.intel.com/en-us/realsense/webapp_setup_v10.exe https://software.intel.com/en-us/realsense/webapp_setup_v10.exe ) failed to download (page not found)
Hi eyalpano,
We would like to let you know that we have already reported that broken link and we are working on it. We'll update you as soon as we have useful information. We'll appreciate your patience.
-Yermi A.
Hi eyalpano,
We would like to let you know that the Intel RealSense SDK Web Component is discontinued due to a security issue with one of the dependencies, and there is no further support for this component and as a result, we had to EOL (End-of-life) and remove all webapp support for the RS-SDK, please take a look at this link for more information: /community/tech/realsense/blog/2017/02/15/intel-realsense-web-component-is-discontinued Intel® RealSense™ Web Component is Discontinued.
-Yermi A.
