Items with no label
3341 Discussions
Left camera on D415/435
I recently learned that there is a left camera (color for D415 and grayscale for D435) that provides a frame perfectly aligned to a depth frame. I enable the stream of standard color camera as follows:
rs2::config cfg;
cfg.enable_stream(RS2_STREAM_COLOR, 640, 480, RS2_FORMAT_BGR8, 60);
How should I modify the code to enable the stream of the left camera? When enabling it, I'd like to specify the size of frame (e.g., 640 x 480) and the frame rate (e.g., 60).
MartyG
In RealSense stereo cameras like the D415 and D435, there are two infrared sensors (left and right) and a single RGB sensor.
The discussion below may help you in mapping color to depth. At the bottom of the page,a user shares their own script for how they did it.
MartyG,
Thanks for your advice as always. Actually, it was my misunderstanding that there was an extra color camera. I figured a way to circumvent the necessity of color-depth alignment with D415 (p. 7 on https://realsense.intel.com/wp-content/uploads/sites/63/BKMs-For-Tuning-RealSense_D4xx_Cameras_WP_1.7.pdf https://realsense.intel.com/wp-content/uploads/sites/63/BKMs-For-Tuning-RealSense_D4xx_Cameras_WP_1.7.pdf )
MartyG
You are most welcome. It's great that you found a solution that works for you.
