Items with no label
3340 Discussions
Looking for clarity on depth perception
RTasa
According to this the sentence
>> The default scale of a D400 device is one millimeter, allowing for a maximum expressive range of ~65 meters.
Which makes sense at a range of 65535/1000 = ~ 65 meters but what does not make sense is the fact in the
Realsense viewer you are defaulted to 4 meters or 12 feet.
Then you read
The depth scale can be modified by calling rs2_set_option(...) with RS2_OPTION_DEPTH_UNITS, which specifies the number of micrometers per one increment of depth. 1000 would indicate millimeter scale, 10000 would indicate centimeter scale,
Centimeter scale? If you increase the RS2_OPTION_DEPTH_UNITS to 10,000 you would be in centimeters per increment which would mean a depth range 650 meters.
Help me here as that does not make any sense.
MartyG
I wonder if it is related to depth of field.
https://en.wikipedia.org/wiki/Depth_of_field# Limited_DOF:_selective_focus Depth of field - Wikipedia
RTasa
The only way this makes sense is if the have it totally backwards.
It defaults to 10,000 (millimeters mode) which gives you a range of ~6.5 meters and seems to
match the 4 meter range meter on the viewer and you can lower it to 1000 (centimeter mode)
which can deliver you 65 meters of range which is ~ 180 feet which would be GREAT if I
make it work in the Realsense Viewer.
Hello ChicagoBob123,
Thank you for your interest in the Intel RealSense D400 Cameras.
The depth units, whether it is .1 mm or 10 mm, does not change the effective range of the camera. It merely affects the units in which depth is reported. If you want a precision of 1 mm in your depth values, then you would not set your depth units to 10 mm.
The 65535/depth_units calculation only gives you the mathematical, theoretical limit but the cameras effective range is still dictated by physics and the environment.
The color gauge on the side of the depth view in the RealSense Viewer is used only for color visualization. It is not the actual range of the camera.
Do not change the depth units while the depth camera is streaming.
Thank you,
Eliza
RTasa
Thanks for the reply.
Is there any place in the documentation that shows the realsense viewer interface and what all the options do or are for?
That would be pretty helpful in understanding the SDK as well as what capabilities the camera has
even though some of the options are clearly marked.
But doesn't it effect the actual return values for distance since you are using 16 bits or 65535?
Your Z16 format? So even if it doesn't limit the range of the camera it alters what it considers
its maximum measured distance.
No I have no use for this. I am not working on a scanner.
This is true of any camera. The camera itself has a pixel density and I am sure the delta tween pixels
become unusable at a certain point in the distance because of the resolution of the camera.
Found this out the hard way.
Hello ChicagoBob123.
You can find more information regarding RealSense Viewer on this user guide : https://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-technology/Intel-RealSense-Viewer-User-Guide.pdf
And regarding your second question, you are right. The mathematical limit is (0-65535)*depth_units. If you have a depth unit of .01 m, the largest depth value would be 655.35 meters. But unfortunately the camera is not capable of reading depth at this distance.
Eliza
Could you please let me know if I can help you with any other information?
Thank you,
Eliza
